Author Topic: Busted Numpad Key  (Read 1926 times)
Offline plobster
Busted Numpad Key
« on: Mon, 05 August 2013, 20:53:42 »
I was messing around with some new blank black caps, replacing the caps in the numpad on the  Ducky DK9008G2(mx blue), when one of the keys sorta got jammed on the switch. when I removed the keycap, the blue switch part got ripped out also. I jammed it back on so it seems to be clicking fine, but the key itself is not registering. What can I do to fix this?
Re: Busted Numpad Key
« Reply #1 on: Mon, 05 August 2013, 21:01:22 »
Desolder and replace it.
Offline plobster
« Reply #2 on: Mon, 05 August 2013, 21:11:06 »
Are there any tutorials I can follow? I am quite the beginner
« Reply #3 on: Mon, 05 August 2013, 21:12:37 »
http://geekhack.org/index.php?topic=46376.msg978914#msg978914
And WhiteFireDragon's Youtube videos will help as well.
Offline plobster
« Reply #4 on: Mon, 05 August 2013, 21:15:28 »
Thanks,
I'll give em I try when i get home
