Author Topic: [IC] DSA CMYK  (Read 14173 times)
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
[IC] DSA CMYK
« on: Tue, 06 August 2013, 00:45:11 »
Would anyone be interested in this? Does Signature Plastics stock a good cyan and a good magenta or would we have to do a custom color order off of pantone?
Offline kenmai9
  • Unicornforce
  • Skrrr
Re: [IC] DSA CMYK
« Reply #1 on: Tue, 06 August 2013, 01:28:29 »
Interests.
Offline stoic-lemon
Re: [IC] DSA CMYK
« Reply #2 on: Tue, 06 August 2013, 02:24:18 »
Let's pretend I need to see a mock up of how this might look before I express interest.....Who am I kidding? Of course I'm interested.
Re: [IC] DSA CMYK
« Reply #3 on: Tue, 06 August 2013, 07:09:17 »
Yes please.  Interested for sure.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] DSA CMYK
« Reply #4 on: Tue, 06 August 2013, 07:53:58 »
Here is what I have for Pantone colors:
Cyan - 16-4529, 3115C, 319C, 3252C, 3255C
Magenta - 226C, possibly one called magenta C.
Yellow - 803C, 102C, or 3945C
The only issue with new colors from Signature Plastics is getting enough of a sale to use the material to warrant a purchase. If we added in CMY colored spacebars and other keys to the DSA CMYK set then it would probably not be hard to hit an order large enough for the new custom colors. Gamer kits could even be done to help make it happen.
« Last Edit: Tue, 06 August 2013, 07:58:54 by danielucf »
Re: [IC] DSA CMYK
« Reply #5 on: Tue, 06 August 2013, 08:18:10 »
CMYK DSA spacebar :eek:
Re: [IC] DSA CMYK
« Reply #6 on: Tue, 06 August 2013, 08:19:38 »
Please no DSA... please?
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: [IC] DSA CMYK
« Reply #7 on: Tue, 06 August 2013, 08:21:50 »
Here's some scans of their ABS and PBT color rings with blues.
ABS
Master Scan - Blues by cpkey, on Flickr
PBT
Blues Master Scan by cpkey, on Flickr
Offline jil_jil32
  • Tokyo Press <3
Re: [IC] DSA CMYK
« Reply #8 on: Tue, 06 August 2013, 08:38:26 »
Interesting...
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] DSA CMYK
« Reply #9 on: Tue, 06 August 2013, 08:45:01 »
When it comes to doing an RGB, I don't care as much about which red, green, and blue are used because there is a little room to play with colors. However cyan and magenta are very specific colors and I think SP doesn't have either one. Some people have also complained about their yellow options so I am not opposed to looking into a better solution for that color as well.
Offline cassist
Re: [IC] DSA CMYK
« Reply #10 on: Tue, 06 August 2013, 10:53:30 »
BFV looks fairly cyan.
plu ml87, poker2
Offline bazemk1979
Re: [IC] DSA CMYK
« Reply #11 on: Tue, 06 August 2013, 16:56:19 »
Daniel you planning on this CMYK to be as complete as Ivans right?
Offline n0rvig
Re: [IC] DSA CMYK
« Reply #12 on: Tue, 06 August 2013, 22:38:05 »
I love the CMYK set from GMK / Ivan. It'd be great to have another chance at CMYK.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] DSA CMYK
« Reply #13 on: Wed, 07 August 2013, 16:09:08 »
That is PBT so unless SP decides they can doubleshoot the legends we want in PBT, or we utilize dye sublimation, that one is a no go.
Yea I don't see why not. Maybe even a touch more elaborate with some matching escapes and other goodies. I personally don't want "Alt Gr" keys, but if others do we can add it on in addition to two regular "Alt" keys. Maybe even do a general CMYK with DCS profile simultaneously. Also speedy.
Offline gnubag
Re: [IC] DSA CMYK
« Reply #14 on: Wed, 07 August 2013, 16:22:26 »
i would like blank CMYK kits in pbt which would be nice with the DSA set from SP.
Offline bazemk1979
Re: [IC] DSA CMYK
« Reply #15 on: Wed, 07 August 2013, 16:25:50 »
btw Daniel something needs to be done with the DSA stem problem, hope Druger and Dololigato can get things fixed before their GB goes into production. Someone needs to have a talk with SP rep.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] DSA CMYK
« Reply #16 on: Wed, 07 August 2013, 18:26:09 »
What is the problem? I have not really had issues with my retro set
Offline bazemk1979
Re: [IC] DSA CMYK
« Reply #17 on: Wed, 07 August 2013, 18:38:31 »
there is a thread regarding people complaining the keycap getting so stuck to the cherry stem that when they try to pull it out the pull out the whole top of the switch.
Offline ChillyVanilly
Re: [IC] DSA CMYK
« Reply #18 on: Wed, 07 August 2013, 18:41:21 »
Seconded.
With the RGB Black & White PBT sets, and the blank DSA Dolch set coming, there are a lot of blank DSA boards out there to warrant this.
Since DSA in't contoured, you could put the 1 unit CMYK caps in any row. You could get unicorn vomit everywhere.
Offline ApocalypseMaow
  • Kitteh Overlord
  • Say WHAAT...
Re: [IC] DSA CMYK
« Reply #19 on: Thu, 08 August 2013, 05:35:15 »
I like this idea
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] DSA CMYK
« Reply #20 on: Fri, 09 August 2013, 08:17:09 »
So bad news for PBT lovers, SP currently only has the ability to sublimate on 1 space, 1.5 space and 2 space key caps so it will have to be ABS.
Good news is, with Esc keys, gamer sets, spacebars, and the actual DSA and DCS CMYK packs we should be able to get custom order color cyan, magenta, and yellow. I'll ask around for some mockups and maybe we can combine it in with a fade group buy.
Offline SeriouSSpotS
  • 60% is love, 60% is life
Re: [IC] DSA CMYK
« Reply #21 on: Fri, 09 August 2013, 13:11:25 »
Interested :D
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
Re: [IC] DSA CMYK
« Reply #22 on: Fri, 09 August 2013, 15:37:34 »
Combining with the Fade...not a bad idea.  Really wish it was PBT, though.  :'(  Probably still in, regardless.  :rolleyes:
Offline gnubag
Re: [IC] DSA CMYK
« Reply #23 on: Fri, 09 August 2013, 17:35:13 »
well, blank pbt could be made (depends on how many people want them)
Re: [IC] DSA CMYK
« Reply #24 on: Fri, 09 August 2013, 18:31:26 »
I would buy a set of blank DSA PBT CMYK.
Offline Sent
  • ¯\_(ツ)_/¯
Re: [IC] DSA CMYK
« Reply #25 on: Fri, 09 August 2013, 18:33:43 »
Hmm...yes, blank pbt would be awesome.  Do want.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] DSA CMYK
« Reply #26 on: Sat, 10 August 2013, 18:52:51 »
Yes but to get the custom color we need to sell a LOT of the material. For just a small quantity of blanks we would have to use the colors SP already has and they will potentially not look as good as the double shots with custom pantone accurate cyan and magenta. Now if we do a "fade" set for 60% boards where black is on the top and bottom rows, and the middle three rows go from cyqan to magenta to yellow, then we can do the other keys as well.
I need to get some mock ups made I think.
Offline pichu23
  • ୧༼ಠ益ಠ༽୨ FITE ME
  • ʕ ͡·ᴥ ͡· ʔ
Re: [IC] DSA CMYK
« Reply #27 on: Sun, 11 August 2013, 13:33:50 »
Interested but it's there a mock up or example ? :D
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: [IC] DSA CMYK
« Reply #28 on: Sun, 11 August 2013, 13:41:14 »
This color scheme is super sick with it.
Offline Game Theory
Re: [IC] DSA CMYK
« Reply #29 on: Sun, 11 August 2013, 13:54:28 »
See Signature plastics own color ring pictures at  http://keycapsdirect.com/colors.php
Note color can definitely depend on your monitor or their camera.
... he's just a poor kid from the stupid ages.
Realforce 104UG | Realforce 91U | IBM SSK | IBM 5251 BeamSpring | IBM Model F XT |  IBM Model F AT | IBM SSK | Filco Majestouch 2 TKL (MX Blue) | KMAC LE (MX Green)| Northgate Omni Key 101 | Avant Stellar Prime
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: [IC] DSA CMYK
« Reply #30 on: Sun, 11 August 2013, 23:19:00 »
Neither pbt or abs has a good magenta, and cyan is questionable. I would rather order off of the pantone number and get exactly the color we want.
Offline yicaoyimu
Re: [IC] DSA CMYK
« Reply #31 on: Fri, 23 August 2013, 14:07:07 »
Interested.
Offline LechnerDE
Re: [IC] DSA CMYK
« Reply #32 on: Fri, 23 August 2013, 14:12:51 »
Offline digi
  • elite af tbh
Re: [IC] DSA CMYK
« Reply #33 on: Fri, 23 August 2013, 14:52:51 »
Definitely in for this if it happens.
Offline funkymeeba
  • CRUMPULAR
  • WEST SHINJUKU PLANTING TUNE
Re: [IC] DSA CMYK
« Reply #34 on: Fri, 23 August 2013, 15:01:18 »
I did not see this sooner! That doesn't make me not interested, though... I am definitely interested. Hit me with them juicy details!
17:15 < vun> these are the healthiest crisps I've ever come across
17:16 < vun> mostly because I can't get the bag open
meebcats - my bad music
  • Kitteh Overlord
  • Say WHAAT...
Re: [IC] DSA CMYK
« Reply #35 on: Fri, 23 August 2013, 18:03:35 »
Can I get some renders in here please!!!
Please!
Offline god
Re: [IC] DSA CMYK
« Reply #36 on: Fri, 23 August 2013, 20:06:06 »
Interested.
Offline fydo
  • Meow!
Re: [IC] DSA CMYK
« Reply #37 on: Fri, 23 August 2013, 21:11:50 »
Interested, depending on price (as always :P )
CoolerMaster Quickfire Rapid | Ducky Shine II (White LED)
Offline Vintage
Re: [IC] DSA CMYK
« Reply #38 on: Sun, 25 August 2013, 17:00:14 »
Interested.
Has anyone tried DSA keycaps mixed with cherry profile at all? Would these be noticeably higher or lower?
CM QFR w/ MX Reds  | Logitech G900
Re: [IC] DSA CMYK
« Reply #39 on: Sun, 25 August 2013, 17:05:06 »
Interested.
Lower
Offline CommunistWitchDr
  • >implying keyboards
Re: [IC] DSA CMYK
« Reply #40 on: Sun, 25 August 2013, 17:09:52 »
I would be all over a pbt dsa edox set. Not really sure which keys though.
Offline thoere
Re: [IC] DSA CMYK
« Reply #41 on: Mon, 26 August 2013, 16:10:52 »
I'm interested in this set, for sure.
Offline Vintage
Re: [IC] DSA CMYK
« Reply #42 on: Mon, 26 August 2013, 21:13:46 »
Interested.
Lower
Hmm thanks  ;D
These would be sick in PBT by the way. Don't even care if we don;'t get legends if it's PBT.
Offline Vintage
Re: [IC] DSA CMYK
« Reply #43 on: Mon, 26 August 2013, 21:20:11 »
Interested.
Lower
Hmm thanks  ;D
I also think spacebars in CMY would be a cool idea too.
Offline bgianf
Re: [IC] DSA CMYK
« Reply #44 on: Tue, 27 August 2013, 22:02:42 »
Interested!
Offline azath92
Re: [IC] DSA CMYK
« Reply #45 on: Wed, 12 October 2016, 15:49:34 »
I would be keen to resurrect this topic. Anyone still interested?
Offline loud_asian
Re: [IC] DSA CMYK
« Reply #46 on: Wed, 12 October 2016, 16:25:20 »
dat necro bump
Would you be hosting the GB yourself? Showing interest for a dead interest check doesn't mean anything if there's no one to carry the torch.
Offline ticktwo
  • -kbdfan
Re: [IC] DSA CMYK
« Reply #47 on: Thu, 10 November 2016, 03:10:46 »
yes! interested
HHKB | Leopold FC750R | Mech27 (soon) | TX-75 (soon)
