Author Topic: Leopold space bar problem  (Read 4439 times)
Offline Jokrik
« on: Tue, 06 August 2013, 09:01:25 »
Hey guys,
Have some issue with leopold space bar, as far as I know the stem gap is different from the one in filco (leopold 42.5 apart and filco is 50 apart i think)
thing is I have some custom keyset (CCnG and retro set) ; the CCnG has the stem at 40 apart and the retro has 50 apart
do you think its better to reposition the CCnG one by cutting it (which I dont know how since my dremel has big cutting disc)
or get a stem from unused keycaps and just plug it on the retro set
or do you guy have any other solution?
I really wanna use either of the set ; else I'll have one of it collecting dust in the cupboard :(
Offline Jokrik
Re: Leopold space bar problem
« Reply #2 on: Tue, 06 August 2013, 09:06:20 »
http://geekhack.org/index.php?topic=41048.msg961299#msg961299
My hero....
now I've to find that Blu Tack tomorrow on local ace, worst case Ill use chewing gum :D
« Reply #3 on: Tue, 06 August 2013, 09:08:06 »
Don't know where you're from but you can find that at Walmart, Target, CVS, Walgreens, etc. It's just removable tack that you use to put up posters and stuff on your walls.
Offline Jokrik
« Reply #4 on: Tue, 06 August 2013, 09:55:04 »
Does it work for you?
can you feel the difference?
I've been tinkering around with something like double tape, or rubber feet from my handy box
none work since I can really feel the difference especially using blue switch, the clicky just gone
Offline esoomenona
  • Gnillort?
« Reply #5 on: Wed, 07 August 2013, 16:12:20 »
What Leopold is it?
« Reply #6 on: Wed, 07 August 2013, 16:14:27 »
I haven't tried it yet. When I do I'll share my thoughts on it in my review.
Offline Jokrik
« Reply #7 on: Wed, 07 August 2013, 22:55:28 »
Actually problem fix !
I tried using different kind of similar stuff to Blu Tack but it just doesn't feel the same
since my retro space bar has 50mm apart stem only, I decided to cut some stems from leftover keycaps and add it to the space bar
with a bit of dremel, sanding and glue work
I have complete step by step picture on the making, but not sure if it would help others since its so basic :D
« Reply #8 on: Wed, 07 August 2013, 23:30:07 »
Hey - a good use for those unwanted crap bag keycaps!
Offline esoomenona
  • Gnillort?
« Reply #9 on: Thu, 08 August 2013, 13:00:31 »
Based on that picture, I'd say FC200R. The universal spacebars that are sold work for the FC200R. FC700R?
« Reply #10 on: Thu, 08 August 2013, 13:01:57 »
They don't work on the 700R. I bought one specifically to try myself. It doesn't fit. Stem spacing still off.
