Author Topic: Custom sized spacebar  (Read 3437 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Tue, 06 August 2013, 21:41:52 »
Anyone here made a custom length space bar by cutting and splicing together multiple doner space bars?  Links would be greatly appreciated.
 Melvang
Re: Custom sized spacebar
« Reply #1 on: Tue, 06 August 2013, 21:43:47 »
If the Spacebar is ABS, couldn't you get acetone or ABS "model glue" (We have some at work) and melt it together? Then stem mod it?
Offline WhiteFireDragon
    • youtube
« Reply #2 on: Tue, 06 August 2013, 23:54:03 »
It sounds possible, but it won't look pretty. You'll see the seams.
« Reply #3 on: Tue, 06 August 2013, 23:56:53 »
Yep, acetone/model glue is the best you're going to get.
Also, 19.05mm=1x, then take 0.5 or 1mm off to account for spacing between keycaps.
« Last Edit: Wed, 07 August 2013, 00:01:12 by Photekq »
