Author Topic: Just got my CM Storm QF TK LE  (Read 1215 times)
Offline klaxhu
« on: Wed, 07 August 2013, 11:57:00 »
Hi guys
I was browsing and browsing one night and just ended up buying the CMS QF TK Limited Edition.
I haven't opened the box because while it was on the way to me, I realised that I might not be able to get used to having the arrow keys and the del/ins/home block of keys mashed up with the rest of them on the numpad.
Except that numpad, this keyboard absolutely ticks all my boxes: MX browns, white+black coloured with white backlight, small & not expensive and I ordered it in the UK.
Before I send it back and re-start my search, maybe needing to get a ducky or maybe something else, is there anything you can tell me about this keyboard?
Should I give it a try anyway and maybe I will get used to the layout? While it won't bother me in gaming, I am using Total commander extensively, as well as word/excel and email where I got used to using the arrows and delete/home/end keys quite a bit. Also maybe fair mentioning is that I don't look at the keyboard at all - the backlight and printed keys is just there for the beauty of it as I would be able to type on a ninja without any problems ... (heh, that is what you get of playing SC2 in the dark without a backlit keyboard for years!! :D )
Also, it is a UK layout and I am worried the shift on the left is a narrow one? Can anybody confirm with a picture? The picture on the box shows a US layout ...
All I want is too not open it and then regret it, and spend another £100+ on another keyboard now as I have to finish my WC-ed PC :D
Andy
« Last Edit: Wed, 07 August 2013, 12:00:48 by klaxhu »
Offline klaxhu
Re: Just got my CM Storm QF TK LE
« Reply #1 on: Fri, 09 August 2013, 18:22:53 »
just sending it back ..i don't like the short shift and the layout at all.
i think i am going for a ducky 2!! :D
