Author Topic: .  (Read 3402 times)
Offline esoomenona
  • Gnillort?
« on: Wed, 07 August 2013, 16:08:33 »
« Last Edit: Fri, 17 October 2014, 18:01:58 by esoomenona »
Re: Alps Keyboards that have the same layout as a Filco Zero?
« Reply #1 on: Wed, 07 August 2013, 16:24:33 »
I've honestly never seen a board with the proper ANSI layout. The AT101W is close but the caps lock has a weird tab on it that won't allow you to use the caps on the board.
Offline bazemk1979
« Reply #2 on: Wed, 07 August 2013, 16:26:49 »
ABS was making them, but not anymore
Offline Photoelectric
« Reply #3 on: Wed, 07 August 2013, 16:53:41 »
Cheapo Ducky keyboards, but you probably wouldn't want their keycaps (not doubleshot either).
« Reply #4 on: Wed, 07 August 2013, 16:54:55 »
Yeah the 1087XM caps will fit but theyre so bad I didnt bother recommending them.
Offline yasuo
  • spanengan puyeng newbie
« Reply #5 on: Wed, 07 August 2013, 17:23:29 »
 1087XM Discontinued :-X
Logitech MK220 Colemak DH
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #6 on: Wed, 07 August 2013, 17:52:28 »
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline esoomenona
  • Gnillort?
« Reply #7 on: Wed, 07 August 2013, 19:28:00 »
« Last Edit: Fri, 17 October 2014, 18:02:07 by esoomenona »
« Reply #8 on: Wed, 07 August 2013, 19:32:07 »
No its literally extra material hanging off the base of the stem. I tried to cut it off to fit my Ducky but then there was just awkward spacing. The stem is centered.
Honestly, the AT101W has all the right caps for a Filco except for the Caps lock. Maybe an AEK set would work other than the Mod row?
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #9 on: Wed, 07 August 2013, 21:33:06 »
you could always go ghetto.......grab a focus board cheap that has ds's- fill out as much as you can
break out the krylon for plastic [paint] and go on about ur biz :))
ask cpt about how man caps you might to paint, match up- can't be but a couple
they would just look like blanks
