Author Topic: o-rings and mx blues  (Read 3764 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
« on: Wed, 07 August 2013, 16:18:25 »
Would o-rings dampen mx blues or does most of the noise come from the switch and not from bottoming out?
Re: o-rings and mx blues
« Reply #1 on: Wed, 07 August 2013, 16:19:57 »
There's noise when you actuate and when you bottom out. My review has videos showing the difference between the two. I personally don't think that o-rings really made Blues that much quieter.
Offline digi
  • elite af tbh
« Reply #2 on: Wed, 07 August 2013, 16:22:51 »
ty sir
« Reply #3 on: Wed, 07 August 2013, 17:06:00 »
I found most noise from blues came from bottoming out, not the clicking of the switch.
Adding O-rings did reduce that slightly, but they are still noisy switches.
« Reply #4 on: Thu, 08 August 2013, 07:43:59 »
I like landing pads with blues, and O-rings with all the others.
- D Trump 2026-10-24
« Reply #5 on: Thu, 08 August 2013, 07:48:16 »
I'm also a fan of landing pads/dampeners on Blues. Used them for a long time before I put a mat underneath my PCB in my 700R
Offline digi
  • elite af tbh
« Reply #6 on: Thu, 08 August 2013, 12:59:48 »
where's a good place to score some landing pads?
« Reply #7 on: Thu, 08 August 2013, 13:00:03 »
EliteKeyboards.com my man
Offline digi
  • elite af tbh
« Reply #8 on: Thu, 08 August 2013, 13:02:22 »
grazie sir...firm or soft?  :eek:
« Last Edit: Thu, 08 August 2013, 13:04:20 by digi »
« Reply #9 on: Thu, 08 August 2013, 13:37:29 »
I like the soft ones.
Offline digi
  • elite af tbh
« Reply #10 on: Thu, 08 August 2013, 14:02:17 »
ordered softies per you and CBA, thanks.
Offline Jixr
« Reply #11 on: Thu, 08 August 2013, 14:29:56 »
I'm currious as trying to dampen blues as well, couldn't you just get a thin foam pad at any hobby store and cut to fit?
Offline digi
  • elite af tbh
« Reply #12 on: Thu, 08 August 2013, 14:32:21 »
I'm sure you could easily find the same material. But for $12 a sheet pre-cut is good for me. I don't really want to sit down with a hobby knife and cut em out.
Offline Hypersphere
« Reply #13 on: Thu, 08 August 2013, 14:51:22 »
In my case at least, most of the sound from my keyboards with blue switches comes from bottoming out. My typing style is heavy, and I bottom out on every stroke.
I did an O-ring mod on my Leopold FC660M using 40A-L (red) rings, which are purported to soften the landing with a minimum effect on key travel. I noticed a substantial silencing -- so much so that I have used the modified board to take notes during conference calls; it would have been too noisy for use during calls before the modification.
Offline Jixr
« Reply #14 on: Thu, 08 August 2013, 15:23:24 »
Well i'm just a poor boy with little money and an impatience for ordering things online.
« Reply #15 on: Thu, 08 August 2013, 15:32:17 »
A few months ago somebody bought a foot of rubber tube and cut thin slices off of it.
Offline Jrwestcoast
« Reply #16 on: Thu, 08 August 2013, 18:14:18 »
quick question for people that use the landing pads.  Do they block the LEDs when you install them?
« Reply #17 on: Thu, 08 August 2013, 19:07:24 »
No, just offset them a little.
Offline Jrwestcoast
« Reply #18 on: Thu, 08 August 2013, 19:28:34 »
Ok thanks for the response   Going to order some for mx blue.
« Reply #19 on: Thu, 08 August 2013, 19:30:15 »
Np, you can also just cut them a little so they fit around the LED.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #20 on: Fri, 09 August 2013, 04:50:30 »
Gawd I miss reds!! Gotta find me some.
SmallFry! <3
Offline digi
  • elite af tbh
« Reply #21 on: Mon, 12 August 2013, 22:42:03 »
Just got done installing the soft landing pads under my blues, not sure I dig it... The reason being is that there is inconsistent bottoming out action due to the various height of the key caps ranging from the bottom to the top of the board. Before the landing pads, every key would bottom out the same. Yea, I think I'm not liking this.. :(
Offline Hypersphere
« Reply #22 on: Tue, 13 August 2013, 09:00:19 »
Are you using the gray or the black soft landing pads (SLPs)? Are they seated properly? (I have not tried these yet; I have only tried O-rings, but I just received some SLPs in both gray and black to try out).
Offline digi
  • elite af tbh
« Reply #23 on: Tue, 13 August 2013, 10:15:19 »
I am using the soft black landing pads. I made sure each pad would sit as well as it could under the cap. On the SP modifiers, the base of the stem doesn't allow the pad to sit at the bottom of the cap so it doesn't work well on modifiers from what I can tell.
On your A-Z keys, because the height of the caps vary throughout each row, the result of the key press varies because some are closer to bottoming out than others. Without the pads, each key press will bottom out exactly the same. This changes when you modify the travel distance with the pads.
I appreciate the attempt for making a product that will quiet down the switches down, but for $18, I wouldn't buy them again.
Offline tricheboars
  • Keyboards are Important!
« Reply #24 on: Tue, 13 August 2013, 15:59:33 »
i use these on plate mounted blues and love them:
http://www.amazon.com/gp/product/B0051XWXCE/ref=oh_details_o07_s00_i01?ie=UTF8&psc=1
for me adding o-rings makes a huge difference in the office. no one complains about my clickity clack after i installed them. i dont like soft landing pads from ek, they make my board feel all rubber domey which is super gross.  i am a huge fan of o-rings on blues. i love 'em.
Offline digi
  • elite af tbh
« Reply #25 on: Tue, 13 August 2013, 16:02:27 »
Thanks for posting those..
