Author Topic: [WTB] High Res IPS Monitor  (Read 4667 times)
Offline Quarzac
  • A very busy dude!
  • Trade Count: (0)
  • Still around, sometimes.
« on: Thu, 08 August 2013, 03:24:50 »
Looking for a Dell Ultrasharp/similar monitor. Wanting 24"-27", resolution of 1920 x 1200 or 2560 x 1440. No dead/stuck pixels please. Thanks in advance!
Risen from the dead for a model F.
Wyse buy colors were GSY for the dark grey, GBA for the light grey, and BBI for the fonts.
  • Trade Count: (0)
Re: [WTB] High Res IPS Monitor
« Reply #1 on: Thu, 08 August 2013, 03:30:57 »
Offline mkawa
  •  No Marketplace Access
  • Trade Count: (0)
  • (ツ)@@@. crankypants
« Reply #2 on: Thu, 08 August 2013, 05:59:31 »
pinged you brodar
Offline loller7
  • Trade Count: (0)
« Reply #3 on: Thu, 08 August 2013, 07:19:26 »
Where do you live?! I got a U2713HM.
Offline Quarzac
  • A very busy dude!
  • Trade Count: (0)
« Reply #4 on: Thu, 08 August 2013, 22:18:25 »
Kawa's is sold, loller lives in Germany. Still looking!
Offline Xenderwind
  • Trade Count: (0)
« Reply #5 on: Thu, 08 August 2013, 22:25:44 »
could get a korean monitor, i love my qnix
GON NS 87 62g clears, QFR 62g clears, Pure 65g blues, HHKB Pro II
Offline omegatony
  • Trade Count: (0)
« Reply #6 on: Thu, 08 August 2013, 22:35:32 »
Got myself a Crossover. Recommended.
Realforce 87U | IBM M SSK | QFR
Offline calavera
  • Trade Count: (0)
« Reply #7 on: Thu, 08 August 2013, 22:38:40 »
Interested in a Benq FP241W? 1920x1200, 24" S-PVA panel located in los angeles area.
Offline Sniping
  • Trade Count: (0)
« Reply #8 on: Thu, 08 August 2013, 22:44:48 »
Qnix all the way!
Offline omegatony
  • Trade Count: (0)
« Reply #9 on: Thu, 08 August 2013, 22:52:18 »
Qnix all the way!
The Qnix looks sexy! Did it just release?
Offline Sniping
  • Trade Count: (0)
« Reply #10 on: Thu, 08 August 2013, 22:56:47 »
Qnix all the way!
Well, it became popular in around March. I picked mine up around April or so. They're pretty much the only affordable OC'able 1440p monitors right now, and the colors out of the box are unparalleled. It's quite the steal atm
Offline omegatony
  • Trade Count: (0)
« Reply #11 on: Thu, 08 August 2013, 23:49:03 »
Qnix all the way!
Whoops, sorry for Hijacking the thread. Got carried away  :rolleyes:
« Last Edit: Fri, 09 August 2013, 00:22:28 by omegatony »
Offline Quarzac
  • A very busy dude!
  • Trade Count: (0)
« Reply #12 on: Fri, 09 August 2013, 01:31:11 »
Qnix all the way!
No problem. Turns out most high res panels require DVI, which my laptop doesn't have, so I think I'm out of luck for now anyways.
Offline omegatony
  • Trade Count: (0)
« Reply #13 on: Fri, 09 August 2013, 02:45:00 »
Qnix all the way!
You don't want to use an adapter? I'm sure you can use a DVI to VGA adapter.
Offline Quarzac
  • A very busy dude!
  • Trade Count: (0)
« Reply #14 on: Fri, 09 August 2013, 03:46:21 »
Qnix all the way!
Apparently a lot of the Korean panels are pretty picky and all but require dual link DVI. I got an offer for a U2410 though, and  that works with VGA.
Offline meiosis
  • Trade Count: (3)
  • Time
« Reply #15 on: Fri, 09 August 2013, 03:54:27 »
Qnix all the way!
DVI is much better than VGA, in the long run your investment will pay off if you purchase a VGA to DVI adapter, and get a nice monitor. VGA to DVI adapters are like $5 on ebay :P.
Keyboards:
Aripeko TKL
Offline alaricljs
  • I be WOT'ing all day...
  • Trade Count: (0)
« Reply #16 on: Fri, 09 August 2013, 08:27:18 »
Those "DVI to VGA" adapters that are $5 are VGA to DVI-A  which is to say 1 analog connector type to a different analog connector type.  It doesn't make it a DVI-D signal.
Filco w/ Imsto thick PBT
Offline MTManiac
  • Trade Count: (0)
« Reply #17 on: Fri, 09 August 2013, 09:38:15 »
Yep, plus they are VERY finicky about even using a single link dvi cable, so you can try your luck with a dvi-vga adapter, plus the signal lost in converting between digital and analog, and the 1600x1200 issue some people have with vga signals not going 1080p, and well I could go on with a list of issues people have doing this, but you could get lucky!
Offline Quarzac
  • A very busy dude!
  • Trade Count: (0)
« Reply #18 on: Fri, 09 August 2013, 16:37:10 »
Yeah, I've just come to terms with the fact that unless I get a desktop out here, I'm not going to have a huge monitor anytime soon. Why do they make laptops with VGA instead of DVI in days like these?
Offline Thechemist
  • Trade Count: (0)
« Reply #19 on: Fri, 09 August 2013, 17:34:21 »
Do you not have an Hdmi / mini-Hdmi  or DP / Mini-Dp port on your laptop? Only the Vga port?
Offline Xenderwind
  • Trade Count: (0)
« Reply #20 on: Fri, 09 August 2013, 17:48:33 »
hdmi and vga should be fine till 1080p, but 1440p requires dual link dvi or a display port(i think active?)
Offline Photoelectric
  • Trade Count: (1)
« Reply #21 on: Fri, 09 August 2013, 18:30:44 »
You could always pick one of these up for great customer service:
http://www.monoprice.com/products/search.asp?keyword=ips+monitor
They have versions with multiple input options.  I highly recommend not using VGA for your signal, as the difference in quality is noticeable (colors are more dull through VGA and sharpness not as good).
Offline Quarzac
  • A very busy dude!
  • Trade Count: (0)
« Reply #22 on: Sat, 10 August 2013, 13:33:50 »
I've got an HDMI port, but I don't know if it works- the last time I tried to use it I had a lot of trouble. Although I'll probably try it, because I definitely notice the difference between VGA and DVI.
Offline Sniping
  • Trade Count: (0)
« Reply #23 on: Sat, 10 August 2013, 13:44:06 »
I'm pretty sure most laptops can't support 1440p monitors.
Offline metafour
  • Trade Count: (0)
« Reply #24 on: Sat, 10 August 2013, 15:16:51 »
My 2011 MacBook Air can
