Author Topic: Looking for super sized spacebar  (Read 5135 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Thu, 08 August 2013, 07:10:37 »
Alright guys I got a bit of a research project for you.  I am looking for any info that would help me track down the elusive 15x spacebar.  According to a post by a fellow GH'er they do exist he just doesn't have his anymore.  I have a thread posted over at DT in both the keyboard section and the marketplace section.  Over there I go by the name of Rotti in case you guys happen to frequent that site more than this one.
Offline Melvang
Re: Looking for super sized spacebar
« Reply #1 on: Fri, 09 August 2013, 04:34:05 »
Nobody has anything on this?  After reading some posts in one of the GH60 threads I am led to believe that they do exist.  And if I remember correctly Samwise and Ivan had actually owned them.  Now I need to try and figure out what old keyboards shipped with them so I can really lurk around on eBay.
Offline bueller
  • MX baller
  • Church of the Ergo Clear
« Reply #2 on: Fri, 09 August 2013, 04:42:47 »
Wish I could help mate, the board mine is on is totally unbranded. I can tell you that it is a Model F copy with Cherry switches instead of BS.
Offline Melvang
« Reply #3 on: Fri, 09 August 2013, 04:45:17 »
Pic please?
Offline bueller
  • MX baller
« Reply #4 on: Fri, 09 August 2013, 04:48:48 »
Done.
« Reply #5 on: Fri, 09 August 2013, 05:54:14 »
That is only a 10x space bar.  My Link terminal keyboard has about a 10x space bar too.  15x would be the entire width of the alpha section, including modifiers.
Offline bueller
  • MX baller
« Reply #6 on: Fri, 09 August 2013, 05:55:10 »
Ah I didn't realise he was specifically looking for a 15x one, we'd discussed my 10 unit space-bar previously.
Offline Melvang
« Reply #7 on: Fri, 09 August 2013, 05:55:49 »
Correct.  There is some mention of these elusive creatures actually existing in the wild in one of the GH60 threads and I have send a PM to both parties involved but no response in a few days.
Offline Melvang
« Reply #8 on: Fri, 09 August 2013, 05:58:28 »
Its all good Bueller.  I actually won an auction on Ebay for a WYSE.  Will post pics after I pick it up today.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #9 on: Fri, 09 August 2013, 06:05:13 »
I think GH60 listed that it could use a 10x or 15x.
finding the space bar itself may be a problem.
SmallFry! <3
Offline Melvang
« Reply #10 on: Fri, 09 August 2013, 06:07:43 »
True but Ivan mentioned that he had one at one point.
Offline bueller
  • MX baller
« Reply #11 on: Fri, 09 August 2013, 06:13:02 »
Nice! Sooo jealous of all the old keyboards available to you guys in the US, out of the 10+ boards I've found locally all but one have been Alps!
« Reply #12 on: Fri, 09 August 2013, 06:19:17 »
Nothing wrong with Alps - you'd get some GHers falling over themselves to buy them off you (depending on which type of Alps they are, of course).
Offline bueller
  • MX baller
« Reply #13 on: Fri, 09 August 2013, 06:26:24 »
Yeah the majority have only really been salvage-able for caps, I'll probably do a FS thread once I have everything cleaned up and sorted.
Offline Melvang
« Reply #14 on: Fri, 09 August 2013, 07:15:37 »
Alright if I can't find a 15x spacebar what do you guys think the chances are of finding a 10x PBT spacebar?
Offline BlueBär
« Reply #15 on: Fri, 09 August 2013, 07:19:22 »
You probably won't find one, PBT tends to crook when cooling down so that's especially hard with such a long spacebar. I think even the standard 6.25 spacebars in PBT sets are sometimes ABS.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #16 on: Fri, 09 August 2013, 07:33:36 »
I hear PBT space bars are worse for that case.
SmallFry! <3
Offline Melvang
« Reply #17 on: Fri, 09 August 2013, 07:42:39 »
Any suggestions on gluing PBT?  Thinking of splicing one together to get somewhere in the 10+ range.
Offline kps
« Reply #18 on: Fri, 09 August 2013, 09:02:18 »
Permabond ES5741. Good luck finding some. You might be able to solvent-weld with MEK; have never tried.
Offline 0100010
  • Not Sure
« Reply #19 on: Fri, 09 August 2013, 09:40:33 »
Only on the Greenock Model Ms are the spacebars ABS - the rest are all PBT.
Offline BlueBär
« Reply #20 on: Fri, 09 August 2013, 10:06:53 »
Nobody mentoined the Model M? SP PBT sets for example have an ABS spacebar.
Offline Melvang
« Reply #21 on: Fri, 09 August 2013, 11:54:50 »
I think I found my solution.  Granted the largest I can go with this method would be 10x without cutting and splicing but I emailed the following via their form online.
 I was wondering if you folks have any molds for a spacebar over the semi standard size of 7 units?  I am looking for a dark gray to black spacebar in PBT in any size between 10 units and 15 units.  Any help in this would be greatly appreciated.
This was my reply
Chris-
Thank you for the request! We have a variety of spacebars over the standard
7 unit size - you can check out the various sizes on our datasheets here:
http://www.keycapsdirect.com/key-caps.php
Let me know if you need anything else!
Melissa Petersen
Signature Plastics LLC
So I head over there to that link and clicked on the link for the DCS family as I think that is the profile that we commonly use for our GB's and lo and behold they can make space bars in the following sizes 4.5, 5, 6, 6.2, 6.75, 7, 8, 9, 9.75, and 10.  Also according to this page they can be made in ABS and PBT.  Now the question is will they let me purchase a couple of them.
Offline bueller
  • MX baller
« Reply #22 on: Fri, 09 August 2013, 11:56:54 »
Space-bar group buy? You know you want to :P
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #23 on: Fri, 09 August 2013, 11:57:55 »
This was my reply
Chris-
Melissa Petersen
They've got 20 10x ABS Spacebars in stock in DCS profile. $2.50 + shipping
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Melvang
« Reply #24 on: Fri, 09 August 2013, 11:58:30 »
This was my reply
Chris-
Melissa Petersen
How did you check that?
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #25 on: Fri, 09 August 2013, 12:04:51 »
This was my reply
Chris-
Melissa Petersen
Marketplace > Inventory
Scroll down and you'll see different lists containing either ABS | PBT links, or DCS | SA / DSA links. Click one and it shows their current stock. Prices are on the previous page.
http://www.keycapsdirect.com/key-capsinventory.php
TOO BAD FOR YOU
Offline bueller
  • MX baller
« Reply #26 on: Fri, 09 August 2013, 12:05:55 »
Make sure you go right to the bottom for the Spacebar inventory though.
Offline BlueBär
« Reply #27 on: Fri, 09 August 2013, 12:06:28 »
They only have ABS spacebars in their inventory, I still think they don't make PBT ones.
Offline Melvang
« Reply #28 on: Fri, 09 August 2013, 12:09:29 »
Thanks guys I will keep in touch with them and let you guys know.
Offline Melvang
« Reply #29 on: Fri, 09 August 2013, 12:14:05 »
Got this as a reply on purchasing a couple that wasn't in stock.
Chris-
We have some DCS 10 unit spacebars in stock available for $2.50 each plus shipping - you and see the list and order from here: http://www.keycapsdirect.com/key-capsinventory.php. Any other spacebars would need to be manufactured - minimum order value is $100.
I hope this helps!
Hmmm wonder if there is enough interest for that many 10x spacebars around here.
Offline Melvang
« Reply #30 on: Fri, 09 August 2013, 12:31:14 »
Chris-
I hope this helps!
Nevermind on the PBT spacebars from SP.
Got this a few minutes ago.
Chris-
There are a few more issues than warping with running the spacebars in PBT, unfortunately we don't mold them at this point in PBT - sorry!
Offline BlueBär
« Reply #31 on: Fri, 09 August 2013, 12:34:45 »
Yep that's what I meant.
« Reply #32 on: Fri, 09 August 2013, 13:41:27 »
link, and wyse terminal spacebars are slightly less than 10x. I think they are 9.75, but I dont have a wyse handy to measure.
the spacebar that was referenced, I don't remember anyone saying the size, but I think he said it had multiple sets of stabilizers (and possibly multiple switches?) I think it was posted on DT. Hopefully that helps.
