Author Topic: [WTB] Raindrop set / BS key caps  (Read 3781 times)
Offline lcs
  • Lover of Grape Drank
  • Trade Count: (0)
  • はやく
« on: Thu, 08 August 2013, 12:10:11 »
Hi, I would like to buy (I have proxies in the US and England):
* BS caps, specially CCs :)
* Raindrop set, or at least the mods.
« Last Edit: Fri, 16 August 2013, 15:36:01 by lcs »
  • Trade Count: (0)
Re: [WTB] GH60, Feng's Filco MJ Case, BS caps
« Reply #1 on: Thu, 08 August 2013, 12:21:36 »
Depending on your case/PCB, you might have to get a stabilizer specifically for that. For example, KMAC only uses PCB mounted Cherry stabilizers. If you clip those, they feel really nice and makes switching caps easier than Costars.
« Last Edit: Thu, 08 August 2013, 12:24:43 by CPTBadAss »
Offline lcs
  • Trade Count: (0)
  • はやく
« Reply #2 on: Thu, 08 August 2013, 12:23:08 »
Depending on your case/PCB, you might have to get a stabilizer specifically for that. For example, KMAC only uses PCB mounted Cherry stabilizers. If you clip those, they feel really nice and makes switches caps easier than Costars.
OK, I get it. Thanks Captain!
Offline jonathanyu
  • Trade Count: (0)
« Reply #3 on: Thu, 08 August 2013, 12:43:11 »
i think qtan have a very similar case, but i am not sure is that exact the one you looking for
Offline lcs
  • Trade Count: (0)
  • はやく
« Reply #4 on: Thu, 08 August 2013, 12:50:30 »
Indeed he has. I hadn't seen it. Still looking for that one though :)
Offline lcs
  • Trade Count: (0)
  • はやく
Re: [WTB] GH60, Feng's Filco MJ Case, BS caps, Phantom kit
« Reply #5 on: Fri, 09 August 2013, 09:02:41 »
Offline dreamingftw
  • Trade Count: (0)
« Reply #6 on: Fri, 09 August 2013, 11:02:45 »
I am selling a BS Key set in my thread if you are interested or were you looking for individual keys?
Offline lcs
  • Trade Count: (0)
  • はやく
« Reply #7 on: Fri, 09 August 2013, 11:05:22 »
Yes, I saw yours. I am looking for individual.
(Also you mention CONUS only :P)
Offline lcs
  • Trade Count: (0)
  • はやく
Offline lcs
  • Trade Count: (0)
  • はやく
Indeed we haven't!
Offline lcs
  • Trade Count: (0)
  • はやく
Re: [WTB] GH60, Feng's Filco MJ Case, BS caps, Phantom kit, Raindrop Set
« Reply #10 on: Mon, 12 August 2013, 14:57:53 »
Offline CalmB4tehPwn
  • Trade Count: (0)
  • Demon of the Fall
« Reply #11 on: Tue, 13 August 2013, 06:57:58 »
If you find a light blue Feng filco case, let me know so I can buy it out from under you.
"I seek a great warrior" - Luke Skywalker
"Great Warrior, Hmm? War does not make one great." - Master Jedi Yoda
Offline lcs
  • Trade Count: (0)
  • はやく
« Reply #12 on: Tue, 13 August 2013, 10:22:16 »
Haha :P
qtan's one is nice too! but let's wait for feng to return :)
The usual daily image:
« Last Edit: Tue, 13 August 2013, 10:29:25 by lcs »
Offline lcs
  • Trade Count: (0)
  • はやく
« Reply #13 on: Wed, 14 August 2013, 09:36:03 »
Offline esoomenona
  • Gnillort?
  • Trade Count: (0)
« Reply #14 on: Wed, 14 August 2013, 09:48:12 »
Case doesn't really have anything to do with it. It's dependent on your PCB and plate. A GH60 has slots for PCB mounted Cherry stabilizers. Also, most of the plates that are made for it allow for the use of both plate mounted Cherry stabilizers and Costar stabilizers (which are only plate mount), as well as allowing PCB mounted Cherry stabs to be used, if so desired.
Technically, you could build a GH60 in the ANSI Poker design you want without a plate, just like an original Poker. You would use PCB mounted Cherry stabs in such a case.
Honestly, the case will probably be your hardest find. You might have some luck searching for a regular black Poker case (or not...) and painting it yourself.
I may have an extra GH60 PCB when everything is said and done, if you have no luck finding what you're looking for. I also have a red Poker plate from a Duck Poker. It doesn't allow you to open switch housings, such as the GH60 plates do.
Offline lcs
  • Trade Count: (0)
  • はやく
Re: [WTB] Raindrop set / BS key caps
« Reply #15 on: Fri, 16 August 2013, 15:37:18 »
C'mon guys, sell me your Raindrop so you can bid on tsangan's clacks!
