Author Topic: Dip Switch Question!  (Read 2143 times)
Offline tehsprayer
« on: Thu, 08 August 2013, 15:20:18 »
I have just got my new keyboard that comes with dip switches and was wondering what you guys use.
I have enabled #2 dip switch that disables the windows keys and I have enabled the dip switch that switches the caps lock for the control key and vice versa > not sure if I like it though.
What do you guys have activated?
REΛLFORCE 87U - uniform 55g
Offline esoomenona
  • Gnillort?
Re: Dip Switch Question!
« Reply #1 on: Thu, 08 August 2013, 15:21:57 »
I think it depends on what keyboard it is...
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #2 on: Thu, 08 August 2013, 15:22:53 »
I think it's a Realforce 87u judging by his siggy.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline tehsprayer
« Reply #3 on: Thu, 08 August 2013, 16:42:11 »
Just curious if anyone else has been trying the caps lock to control switch
Offline esoomenona
  • Gnillort?
« Reply #4 on: Thu, 08 August 2013, 16:43:08 »
I have it that way on my HHKB, and then eventually preferred it. So I also made that change on other keyboards.
