Author Topic: Extended Spacebar like the Steelseries Apex for cherry switches.  (Read 3175 times)
Offline FrostyToast
  • Litshoard
Do any of you know if I can get an extended spacebar as seen on the Steelseries Apex? It would make typing and gaming much more comfortable for me as I naturally end up having my thumb rest below the spacebar.
Quote from: elton5354
Offline BlueBär
Re: Extended Spacebar like the Steelseries Apex for cherry switches.
« Reply #1 on: Fri, 09 August 2013, 08:40:05 »
I have never seen such a spacebar for a mech and doubt that it exists. It also wouldn't fit in a normal case (GON's cases would work though, also that Pure CNC case that is kind of similar).
Offline strafe
    • Strafe's Blog
« Reply #2 on: Fri, 09 August 2013, 22:44:07 »
Gigabyte do one.  http://www.gigabyte.us/products/product-page.aspx?pid=4179#ov
But as said earlier you wouldn't be able to use it on another keyboard unless you built a custom case.
Freebird WKL (Blacks Clear-Tops), iKBC F-104 (Blacks) and more!
Offline Topre
« Reply #3 on: Fri, 09 August 2013, 23:01:17 »
You can glue a piece of plastic, metal, or cardboard on to your spacebar. That way it will extend as much as you want. You can probably even use it as a wrist rest spacebar, if you made it big enough.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #4 on: Fri, 09 August 2013, 23:34:10 »
Your best bet would probably be to have one milled out of titanium as new plastic molds are like a few grand. You could probably get Hammer to do it, it wont be cheap but it'll be beautiful.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline jacobolus
« Reply #5 on: Mon, 25 January 2016, 19:14:37 »
Necro-ing this thread...
Someone really needs to make an MX keycap in the same dimensions (2.5x1.5u) as the Matias ErgoPro spacebar, so that new-layout keyboards can use that shape with both MX and Alps switch compatibility.
Spacebars on standard keyboards are about 1/2u too close to the letter keys, but nobody wants a keyboard with an awkward 1/2u gap between keys.
Pic for reference:
Offline FrostyToast
  • Litshoard
« Reply #6 on: Mon, 25 January 2016, 19:21:26 »
Woah.
Who the hell made this thread?
Is that me?
****, I was a totally different person back then.
Type travel is possible!
