Author Topic: KBT Pure Pro 60% Question  (Read 3963 times)
Offline ror.mc
« on: Fri, 09 August 2013, 08:05:10 »
Heya, just joined up today, been a frequent lurker for a while. Now though i need your help as im looking for a backlight 60% keyboard with dedicated arrow keys. I've looked for a while and only found the KBT Pure Pro. I would just buy this but i would like to know how easy it would be to customize? Thanks!
Re: KBT Pure Pro 60% Question
« Reply #1 on: Fri, 09 August 2013, 08:09:18 »
What do you mean by "customize"?
You want to replace the keycaps? Or mod it to have different LEDs? Or swap the case? Or reprogram the layout?
Offline ror.mc
« Reply #2 on: Fri, 09 August 2013, 08:10:47 »
Hi sorry yea im just a beginner i mean just getting replacement key caps.
« Reply #3 on: Fri, 09 August 2013, 08:19:09 »
Can't find an ANSI layout (I'm not sure what layout you're looking for) but it's going to be a mess to try and replace those caps.
http://kbtrace.com/kbtpure/home-page-products/kbt-pure-pro-60-blue-light-qwertz-german.html
If you look at the link, it's all 1x caps in the bottom right and there's no sets with the proper profile. Ever look into 75% boards like the KBT Race or MX Mini?
Offline ror.mc
« Reply #4 on: Fri, 09 August 2013, 08:28:08 »
ahh i had not considered 75% before, they look good, which one would you recommend? I need back lighting and the ability to easily change key caps would be brilliant. Thanks again.
Offline therecorder
« Reply #5 on: Fri, 09 August 2013, 08:33:31 »
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/pbt-key-caps-87-104-full-set/pure-pro-replacement-caps/lid=36275351
Part of Qtang's Note:
Pure Pro set for geekhack order.  It is sold as a Full set of caps, do not ask just party of the set, thanks.
Please notice that although I am using the Poker 2 picture for Pure, the color is the same, all order is full set of replacement caps, 61 for poker and 67 for Pure.
« Last Edit: Fri, 09 August 2013, 08:35:08 by therecorder »
Offline ror.mc
« Reply #6 on: Fri, 09 August 2013, 08:36:08 »
Thanks for that link, althought the pictures seem to show the pure without the dedicated arrow keys.
Offline therecorder
« Reply #7 on: Fri, 09 August 2013, 08:44:11 »
Please notice that although I am "using the Poker 2 picture for Pure", the color is the same, all order is full set of replacement caps, 61 for poker and "67 for Pure".
« Reply #8 on: Fri, 09 August 2013, 08:48:48 »
The 75% boards I like will be expensive or not have backlighting. They'll also have weird layouts on the caps so you won't be able to swap them.
I have an Epsilon and a Siig Minitouch. I'd recommend an MX Mini but its expensive for a beginner and I'm not sure it has backlighting.
I forgot, that the Filco Minila is out too which should have an easily replaceable keycap set.
Offline ror.mc
« Reply #9 on: Fri, 09 August 2013, 09:00:42 »
I have some money saved up so i dont mind if its expensive and i can live without backlighting, i just really want i small sized keyboard either 60 or 75% thats really easy to change keycaps with. Thanks again for your help!
Offline therecorder
« Reply #10 on: Fri, 09 August 2013, 09:13:57 »
Qtang also sells the Pure Pro keyboard, an all white ANSI version, but it does not have backlighting.  As yet, I don't think that  there is a Pure Pro ANSI version with backlighting:
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/shop-mechanical-keyboard-by-sw/kbt-pure-pro-67-keys-mechanica/lid=35326529
mechanicalkeyboards.com does have some Keycool 84s with backlighting, but I'm not sure how easy it would be to find replacement keycaps.
Go through the following page:
http://mechanicalkeyboards.com/search.php?switch_id=ALL&size=Tenkeyless&keyword=keycool&backlit=on&in_stock=on
« Last Edit: Fri, 09 August 2013, 09:17:04 by therecorder »
Offline ror.mc
« Reply #11 on: Fri, 09 August 2013, 09:51:45 »
Thanks for your help!
