Author Topic: Troubleshooting - Laptop  (Read 2986 times)
Offline GeekMark2
« on: Fri, 09 August 2013, 10:57:05 »
Hey!
Anyone else had this problem...every time I switch my computer off, it does updates. That's every SINGLE time...and it's always 11, or more sometimes.  :eek: I mean, I know that it does happen sometimes, but if it is every time, does that mean there's a problem with it?
Help me pleaseeee :)
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
Re: Troubleshooting - Laptop
« Reply #1 on: Fri, 09 August 2013, 10:59:53 »
It sounds like the updates are failing to install. Go to the start menu, type in Windows Update, click it, and click View Update History. Does it say for any of them under Statues, "Failed" or are they all "Successful"?
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline lcs
  • Lover of Grape Drank
  • はやく
« Reply #2 on: Fri, 09 August 2013, 11:00:04 »
« Reply #3 on: Fri, 09 August 2013, 11:00:53 »
Hey!
Anyone else had this problem...every time I switch my computer off, it does updates. That's every SINGLE time...and it's always 11, or more sometimes.  :o I mean, I know that it does happen sometimes, but if it is every time, does that mean there's a problem with it?
You just need to change your windows update settings, basically what it sounds like it is doing is downloading and installing them automatically.
Offline GeekMark2
« Reply #4 on: Mon, 19 August 2013, 09:47:39 »
Ok thanks. So, do I just need to change them from 'automatic' to 'manual' ?
Offline GeekMark2
« Reply #5 on: Mon, 19 August 2013, 09:49:25 »
Hey. Thank you for the advice, I checked and there are 2 that say 'Failed'..could you give me some advice on what to do next please?
Thank you!
« Reply #6 on: Mon, 19 August 2013, 09:51:14 »
You could try it and see what happens.
I'm curious to know what it is set at now?
Thank you!
It should give you the option to see what the problem was/is. But if it's failing that could be why it keeps prompting you also.
