Author Topic: Cherry Stabilizer wire  (Read 15193 times)
Offline Germiphene
« on: Fri, 09 August 2013, 11:43:15 »
Hey, anyone know any good online supplier of the correct thickness and strength of the cherry stab wire.  I'm missing a few so I figured I'd bend them myself, but I can't find good wire for it at home depot or lowes.  Anyone have a advice on this?
HHKB pro | RF 87U | RF 87U uni-45g | CM QFR | Steelseries 6Gv2 | Filco MT2 | IBM model M | IBM SSK '87
Offline MJ45
  • HHKB Pro
Re: Cherry Stabilizer wire
« Reply #1 on: Fri, 09 August 2013, 12:00:54 »
Check hobby shops I here that piano wire works good.
« Reply #2 on: Fri, 09 August 2013, 12:05:10 »
Check out Litster's video. I know it says Costar but Cherry is just the two bends on the ends instead of the 4 bends total.
Description:
"How to make a Costar spacebar stabilizer bar by hand. You need a Du-Bro E/Z Bender (0-90 degrees and Z bend). Wire need to be 3/64 inch music wire that you can find at hobby shops. I found the ones I use at Hobby Town USA. It is called K&S Precision Metals Stock # 502 0.047 Music Wire (1.19mm)."
Offline esoomenona
  • Gnillort?
« Reply #3 on: Fri, 09 August 2013, 12:07:44 »
Costar uses much thinner wire than Cherry stabs do.
Offline PepperPanda
« Reply #4 on: Fri, 09 August 2013, 14:11:12 »
I used brass 1/16 wires I found at a local hobby/art store, for my cherry stabilizers.
« Last Edit: Fri, 09 August 2013, 14:17:05 by PepperPanda »
Offline Germiphene
« Reply #5 on: Sat, 10 August 2013, 21:11:49 »
Thanks all.  Yeah I'll take a look around a hobby store here, when I get a chance.
Offline HeroXLazer
« Reply #6 on: Wed, 25 January 2017, 20:34:22 »
I know this is very old, but what length does the wire have to be at the bend for a 2u wire? Also, how do you bend brass and do you have any links?
« Last Edit: Wed, 25 January 2017, 20:40:14 by HeroXLazer »
Offline ReadmeDotTxt
« Reply #7 on: Wed, 25 January 2017, 22:59:50 »
You can bend any material of wire the same way the do it in the above video.
Offline Wingklip
  • I am the one the one the one the one the one
« Reply #8 on: Fri, 03 February 2017, 21:40:01 »
Pliers and a vice
If you 1v1 me in a cage fight I will use an AK-74 for ranged and an IBM model F 122 for melee
