Author Topic: Making HexChat exec a text file of commands  (Read 2836 times)
Offline alosec
« on: Fri, 09 August 2013, 23:02:35 »
Someone in an IRC told me that this was possible but I haven't figured out how to do it.
I want to have my IRC client (HexChat) exec two commands when I connect to GameSurge:
/authserv AUTH alosecs *****
/umode +x
This will log me into the GameSurge network and mask my IP and location from everyone when I join the channel.
Offline Jack
Re: Making HexChat exec a text file of commands
« Reply #1 on: Fri, 09 August 2013, 23:27:24 »
Not sure if this will work in Hexchat, but it's all I can find, and maybe it's still similar enough. https://toxin.jottit.com/xchat_connect#10
If the first command doesn't work you might have to use "/quote authserv" or "/msg authserv@services.gamesurge.net" instead.
Offline alosec
« Reply #2 on: Fri, 09 August 2013, 23:43:29 »
I think this is exactly what I was looking for... Pretty sure you just googled it, but you googled it better than me. Thanks mate.
Offline Jack
« Reply #3 on: Fri, 09 August 2013, 23:48:52 »
And that's the whole of the tech support industry. Enjoy. :)
