Author Topic: Good toner for my printer  (Read 2274 times)
Offline yester64
« on: Sat, 10 August 2013, 14:21:57 »
Hi, i have a brother 2240d printer which i actually really like. My problem is only that the toner i bought is pretty sad. Since the toner is almost done, i like to buy a new toner cartridge but i wonder if there is a good offbrand that i can use and that produces a good quality print out.
Refilling my self i don't want to do since it is also toxic anyway. Or i buy the genuine toner cartridge from brother. Mm... Anyone has a tip for me which brand or non brand is ok so i don't have to go through buying.
Thanks
p.s. last time i bought some toner of amazon i think. just ok not great. one side is thin in black. :(
Rosewill RK-9000BR (trashed)
WASD V1 Keyboard Cherry Blue w/40A Hardness O-Rings
Steelseries 6GV2 Red Cherry Switches
Re: Good toner for my printer
« Reply #1 on: Sat, 10 August 2013, 22:42:13 »
Personally I would tend to stick to the manufacturer's toner.  I acquired a nearly new Dell colour laser printer because it was making a loud grinding noise, and the person did not want to get it repaired.
Turns out the problem is almost certainly the non-Dell magenta cartridge.
Thing is, it is $70 for magenta from Dell.  One day I might get around to it, but need black too, so $140.
Or just buy another new printer with the factory toner and dispose of the old one - with careful selection this could turn out to be cheaper.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Sun, 11 August 2013, 00:50:09 »
I have a Xerox 6505 that I recently replaced the black toner with a cartridge I bought from Meritline for ~$18.  It detects as official Xerox toner and prints just as good.
Filco w/ Imsto thick PBT
Offline yester64
« Reply #3 on: Sun, 11 August 2013, 10:30:03 »
Ah, well the original toner is most likely always expensive. I feel you just pay for the brand mostly and it is even almost as expensive as the printer itself. The original brother toner cost about $60, printer itself runs about $100.
But i will try the Meritline, although i seen the same cartridges on Amazon as well. Thanks for the tip.  :thumb:
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #4 on: Sun, 11 August 2013, 11:22:35 »
I'VE NEVER TRIED IT, BUT PERHAPS THERE COULD BE A WAY TO REFILL THE POWDER IN THE TONER CARTRIDGE? I'VE USED INK REFILL KITS WITH MY INKJET PRINTERS AND HAVE HAD GOOD RESULTS.
