Author Topic: Is there a way to restore original key cap coating  (Read 2875 times)
Offline Inertially
« on: Sun, 11 August 2013, 02:33:28 »
After some use, the matte textured coating on key caps wears off.
So, the keys then look dark/smooth/shiny.  They also feel sticky/terrible.
Is there a way to restore the original finish?
Anyone know what the coating is?
Re: Is there a way to restore original key cap coating
« Reply #1 on: Sun, 11 August 2013, 03:19:34 »
The inevitable ABS keycap shine.  There isn't really, you'd just replace the keycaps with new ones to get uniform colour and texture across the board.
Or go PBT, which has a slight texture, and also resists shining for considerably longer.
