Author Topic: [LF] WYSE ~` Key - FOUND!  (Read 2488 times)
Offline oTurtlez
  • DAT ZACKATTACK
  • Trade Count: (0)
  • Fo' Realforce
« on: Sun, 11 August 2013, 12:06:59 »
So the WYSE set I got had a black and grey ~` key while all of my other keys are the typical white and blue / grey and blue keys. Pretty much, anyone got a blue and grey / blue and white ~` keycap?
« Last Edit: Sun, 11 August 2013, 12:39:22 by oTurtlez »
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline BunnyLake
  • The OG HHKB Master
  • Trade Count: (3)
  • X
Re: [LF] WYSE ~` Key
« Reply #1 on: Sun, 11 August 2013, 12:09:25 »
i got you bro
send me your address
Offline dreamingftw
  • Trade Count: (0)
« Reply #2 on: Sun, 11 August 2013, 12:09:52 »
I thought I included the original in the set I sold you? The black on grey I got from the SP crap bag, which has the same profile as the number row. The original has a lower profile. I remember putting in both in the bag.
Offline oTurtlez
  • DAT ZACKATTACK
  • Trade Count: (0)
  • Fo' Realforce
« Reply #3 on: Sun, 11 August 2013, 12:13:36 »
I'll check right now, I definitely could've missed it with a duplicate in there haha.
i got you bro
Hallelujah! Thanks bud, I'll let you know if I can't find it.
TOO BAD FOR YOU
Offline oTurtlez
  • DAT ZACKATTACK
  • Trade Count: (0)
  • Fo' Realforce
« Reply #4 on: Sun, 11 August 2013, 12:15:21 »
Ok, so it is here, but like you said it seems to be an R2 or R1 profile. Bunny, is the one you've got an R4?
TOO BAD FOR YOU
Offline BunnyLake
  • Trade Count: (3)
  • X
« Reply #5 on: Sun, 11 August 2013, 12:17:42 »
it is indeed an r4 sir, im a super profile nerd
shoot me a pm with your address and its yours, also, might be worth popping the set on and make sure you arent missing anything else, sometimes those setss have some odd stuff, let me know what you need
Offline oTurtlez
  • DAT ZACKATTACK
  • Trade Count: (0)
  • Fo' Realforce
« Reply #6 on: Sun, 11 August 2013, 12:21:27 »
I've got the set on now, just didn't notice it wasn't blue once it was in the sunlight haha.
I believe the only other missing keys are from the 6key cluster above the arrows, PgUp + Down, Home, End, Delete, and Insert. but I've got a setup for those that is fine for now.
TOO BAD FOR YOU
Offline dreamingftw
  • Trade Count: (0)
« Reply #7 on: Sun, 11 August 2013, 12:35:48 »
Yeah the keyboard I got it from didn't have that cluster.
Offline oTurtlez
  • DAT ZACKATTACK
  • Trade Count: (0)
  • Fo' Realforce
« Reply #8 on: Sun, 11 August 2013, 12:38:15 »
Ahh, no worries, I love the set regardless :)
TOO BAD FOR YOU
