Author Topic: Where to buy KBT pure PRO  (Read 4680 times)
Offline Squezz
« on: Mon, 12 August 2013, 13:58:41 »
Hi,
im looking for the PRo version of the KBT pure board.
Why are there only ISO layouts left :/ ? i would love to buy a black keyboard with ansi layout.
any idea where i could get one?
i really like the macro function and the dedicated arrow keys, so the non pro isnt an option for me.
thanks for help,
cheers
Offline spiceBar
    • ChessTiger.com
Re: Where to buy KBT pure PRO
« Reply #1 on: Mon, 12 August 2013, 14:57:45 »
I have found one on ebay:
http://www.ebay.co.uk/itm/KBT-Pure-Pro-Mechanical-Keyboard-Cherry-MX-Brown-Switches-W-White-PBT-caps-/290928771251
However it has no backlighting. But you get white PBT caps on this one.
Please note that I have absolutely no connexion with the seller.
You should really try google.com. You really can find stuff with this tool. ;-)
NOTE: for those who want an ISO FR/DE/UK/ES layout, you can find it there:
http://kbtrace.com
That's where I've got the two I currently own (one with browns, one with reds).
« Last Edit: Mon, 12 August 2013, 15:00:36 by spiceBar »
Offline Squezz
« Reply #2 on: Tue, 27 August 2013, 07:13:41 »
http://kbtrace.com
well.. i used google.. thats why iam asking here, because i didnt found anything - except the white ones you posted
Offline Obakemono
« Reply #3 on: Tue, 27 August 2013, 07:27:21 »
Offline hcry4
  • HHKB Hoarder
« Reply #4 on: Tue, 27 August 2013, 07:29:12 »
Massdrop group buy has the backlit version. Thread here.
Offline Krigo
« Reply #5 on: Tue, 27 August 2013, 09:36:19 »
Offline Squezz
« Reply #6 on: Wed, 28 August 2013, 04:35:23 »
ah thanks guys, i think ill join the massdrop groupbuy !!:)
the other links are non PRO versions - or white ones , but thx anyway :)
