Author Topic: stabilizer adapter too small?  (Read 4203 times)
Offline digi
  • elite af tbh
  • keyboard game on fleek
« on: Mon, 12 August 2013, 20:58:27 »
I was taking off my caps for the first time on my Rosewill 9000 and I noticed that the stabilizer adapters (sorry don't know the proper name) just fall right out? Pretty much makes the stabilizers useless since they wont stay inserted in the cap. Do I need different adapter thingys?
Re: stabilizer adapter too small?
« Reply #1 on: Mon, 12 August 2013, 21:03:35 »
I've had that issue before, on my QFR (blacks). It doesn't feel too different from my filco (reds). It's a pain in the ass to put back on, but it's doable. Just put a little piece of paper in between the stabilizer and the keycap to keep it in place.
Offline alaricljs
  • I be WOT'ing all day...
« Reply #2 on: Mon, 12 August 2013, 21:04:33 »
You need plastic wrap, or tape, or a plastic bag.   This is a common issue w/ SP caps and costar stab inserts.  1 layer of plastic bag, a couple of plastic wrap... whatever works for you.
Filco w/ Imsto thick PBT
Offline digi
  • elite af tbh
« Reply #3 on: Mon, 12 August 2013, 21:05:21 »
cool, thanks yall.
« Reply #4 on: Mon, 12 August 2013, 21:22:56 »
I have successfully used small (~1cm square) pieces of plastic sandwich bag.
Others have used teflon tape and sticky tape.
I think loose is better as it is easily remedied.  Too tight - I have nearly lost finger nails trying to get some inserts out!
Offline ___q
« Reply #5 on: Mon, 12 August 2013, 23:26:24 »
I've used (needle-nose) pliers in the past to pull out particularly stubborn ones. It works way better than fingernails.
Offline PointyFox
« Reply #6 on: Mon, 12 August 2013, 23:28:54 »
I use ripped pieces of tissue paper/toilet paper/napkins/etc.  Easier to remove than other things since you can just break it up in water if it gets stuck which it hasn't yet.
« Reply #7 on: Mon, 12 August 2013, 23:30:20 »
I found that the small squares of plastic sandwich bag are sufficiently slippery that the stem will come out fairly easily if pulled, but hold it in tightly enough that none have fallen out during normal use.
Offline Danule
« Reply #8 on: Tue, 13 August 2013, 01:42:27 »
I had this issue with my doubleshots.  I used some cut up plastic shopping bag and it worked fine.
45g Brown Brown Blue
Offline oaklandishh
« Reply #9 on: Tue, 13 August 2013, 18:58:42 »
I used toilet paper as well. Get two ply though, or its too thin.
« Reply #10 on: Tue, 13 August 2013, 19:07:02 »
I use tissue
« Reply #11 on: Tue, 13 August 2013, 19:15:00 »
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #12 on: Tue, 13 August 2013, 20:39:01 »
ha.......!
thought i was the only one........... :thumb:
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline oaklandishh
« Reply #13 on: Tue, 13 August 2013, 23:58:14 »
ha.......!
Yeah and you always have toilet paper.... or you have bigger issues at hand than stabilizers not fitting.
Offline digi
  • elite af tbh
« Reply #14 on: Tue, 13 August 2013, 23:59:29 »
Yea, a few wraps of plastic wrap is the bizz, works like a champ. I can use my stabilizers now, whoaaaaaaaa
