Author Topic: oldest model m space saver?  (Read 5709 times)
Offline dem0critus
« on: Tue, 13 August 2013, 08:47:40 »
 oldest model m ssk?
Offline tipo33
  • "Ski"
Re: oldest model m space saver?
« Reply #1 on: Tue, 13 August 2013, 08:53:48 »
Ummm... I duno.  I don't think so.  Mine is an '87.  I will have to check the date though.
KM4COL    R.I.P.  SmallFry
Offline dem0critus
« Reply #2 on: Tue, 13 August 2013, 08:56:21 »
Check! I've been digging a little, and the oldest ones I've found are from may/june of '87.
Offline tipo33
  • "Ski"
« Reply #3 on: Tue, 13 August 2013, 09:10:50 »
I will, it will be about a week.  Sorry :(
Offline dem0critus
« Reply #4 on: Tue, 13 August 2013, 09:13:46 »
no hurry! I'm just curious :)
« Reply #5 on: Tue, 13 August 2013, 10:19:07 »
Doesn't clikcykeyboards.com keep a database on all the IBM Model Ms?
- Plato
Offline snoopy
  • The Flying Ace
  • Gone with the Wind
« Reply #6 on: Tue, 13 August 2013, 10:25:23 »
I remembered this other thread about ssk production dates: http://geekhack.org/index.php?topic=39128.msg761926#msg761926
seems like you have a really old one, but don't know if it's the oldest :)
/edit
here is the list from clickykeyboards about the ssk: https://docs.google.com/spreadsheet/ccc?key=0Amwr_8tmy8pZdDAtWExCUzlma2Qzc0hCY3hzUExFZFE#gid=0
« Last Edit: Tue, 13 August 2013, 10:27:09 by snoopy »
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #7 on: Tue, 13 August 2013, 10:33:21 »
Forward the number and a picture of the label to Clicky Keyboards for his database of Model Ms
Offline dem0critus
« Reply #8 on: Tue, 13 August 2013, 10:39:58 »
Yeah, they do.  Oldest they have is june 87, but the database they have on ssks isn't very big (only 30 entries), so I'm assuming that only scratches the surface.  I've looked basically everywhere I can think of (geekhack threads included), and haven't even found one with the same part no. as this one.  I figured the only other place to check was this forum and deskthority.
I sent them a message on fb, but the database submit seems to be for certain part numbers only, and mine isnt listed in the dropdown here:http://www.clickykeyboards.com/index.cfm/fa/pages.main/pageID/3 (unless im looking in the wrong place).
edit: w/ a little firebugging I was able to add it to the spreadsheet with the proper part no.  I hope they don't mind! :O
« Last Edit: Tue, 13 August 2013, 10:59:05 by dem0critus »
Offline JimByr
  • ...old guy...
« Reply #9 on: Fri, 04 March 2016, 12:00:11 »
To keep all of the information in one topic...
I picked up another 1390359 that appears to be the earliest production SSK found yet.
Part No. 1390359
ID No. 2000132
Date 02/04/1987 (4 Feb 1987)
Plt. F2
origin: IBM / (c) IBM Corp. 1984
The chip version (1390538) is one step up from the chip on the 1390359 engineering model recently found by HULLO8D (1390537). The chip is soldered. The bottom of the case is like later SSKs with the speaker opening. The 'Enter' key is printed 'Return' with 'LF' on the front. The key cap characters have more ink than later boards (like other early Model M boards).
I'd characterize the board condition as 'poor' (case, keys, heavily oxidized steel plate, 15 broken rivets) and the external damage is 'recycler damage'. However, the board has all keys and can be cleaned up and bolt-modded and will be perfectly usable.
« Last Edit: Fri, 04 March 2016, 12:03:11 by JimByr »
Offline snoopy
  • The Flying Ace
« Reply #10 on: Fri, 04 March 2016, 14:17:27 »
nice find!
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
« Reply #11 on: Fri, 04 March 2016, 16:54:02 »
I didn't know the SSK arrived so much later than the normal Model M Oo .
« Reply #12 on: Sat, 05 March 2016, 04:34:37 »
My oldest one is merely 13-Oct-1987 - so quite young in comparison!
