Author Topic: Can't decide on which keyboard to buy next!  (Read 5527 times)
Offline TimIsABat
  • MX Clears are life
    • Instagram
« on: Tue, 13 August 2013, 22:20:41 »
So I just bought an IBM Model M from TheFlyingRaccoon (thanks bud)! And now I am already deciding on which board to get next!
So far I have almost every board to satisfy my trying needs:
FC660M with MX Reds (satisfying my linear taste)
Poker X with ergoclears (tactile heavier needs but out of commission at the moment)
IBM Model M (classic, heavy, tactile, buckling spring)
Dell AT101 (tactile ALPS feel need)
Compaq RT101 (good quality stock rubber dome need)
Now its time for my next switch: Topre...
I like a small form factor like my Poker X and FC660M because I can easily travel and rotate them On-The-Go, but I have yet to use a 87 keyboard.
I am debating on getting a Realforce 87u in white with 55g springs or a HHKBPro2 in white blank which has 45g springs.
I am split because I am really used to the uber light switches on my mx red because I am stuck using this ATM (didn't get my model m yet), but I also really like the ergoclears on my poker x before i screwed it up somehow.
I'm asking for some reasons to pick one over the other.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline ishpeck
  • Life without MX Blues is no kind of life at all.
    • The Ishpeckian Network
Re: Can't decide on which keyboard to buy next!
« Reply #1 on: Tue, 13 August 2013, 22:24:37 »
I'm fond of having CTRL where capslock tends to be.  It's one of the first things I do when I install a system.  The Happy Hacking keyboard would save me that effort.
0:=λfx.x
Offline TimIsABat
    • Instagram
« Reply #2 on: Tue, 13 August 2013, 22:26:54 »
I used to do this until I switched to Colemak where capslock is backspace which is far more efficient than capslock as CTRL imo.
« Reply #3 on: Tue, 13 August 2013, 22:36:14 »
Compromise and get FC660C?
It has dedicated arrow keys, the one biggest thing I miss on HHKB2Pro.
Offline TimIsABat
    • Instagram
« Reply #4 on: Tue, 13 August 2013, 22:38:06 »
I was thinking about it, but I am using a FC660M right now, and the one thing that I really don't like on this is the awkward spacing on the board. the keys seem to be really squished together causing a lot more errors made than when I use my Poker X.
« Reply #5 on: Tue, 13 August 2013, 22:41:48 »
Then if you want very non-standard layout - HHKB2Pro.
If you want standard layout: RealForce.
Offline TimIsABat
    • Instagram
« Reply #6 on: Tue, 13 August 2013, 22:43:01 »
That's the problem x.x . IDK XD. I have time to decide though. Let's see how I feel about standard layout again when I get my Model M
Offline jameslr
« Reply #7 on: Tue, 13 August 2013, 22:49:37 »
You can do this with the Realforce as well.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
« Reply #8 on: Tue, 13 August 2013, 22:58:17 »
FWIW I've just temporarily gone from HHKB to Model M at home.  I had just about gotten used to the HHKB layout and size, now I find myself reaching all over the place to press keys on the M.
Offline jabar
« Reply #9 on: Tue, 13 August 2013, 23:04:34 »
Is that really true? I have noticed more typos with the FC660C but I'm not sure if the spacing between keys was altered. It doesn't have a different row offset like the Minila which is terrible for that reason, and the layout, and the case...
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline czarek
  • Keep the momentum going!
    • FalbaTech
« Reply #10 on: Wed, 14 August 2013, 03:23:31 »
I noticed you don't have blue mx in your collection :) May be a step before going Topre?
Offline TimIsABat
    • Instagram
« Reply #11 on: Wed, 14 August 2013, 06:26:28 »
Not really blue fan. I've tried it and it just sounded high pitched and cheap to me.
Offline vsdubstep
« Reply #12 on: Wed, 14 August 2013, 13:51:20 »
I cast my vote for 60%
Offline thebeargentile
« Reply #13 on: Wed, 14 August 2013, 13:57:00 »
I have an HHKB and 87U, and in my opinion, the HHKB is the more "fun" of the boards... the 87U has a fantastic build quality, and feels solid to type on, but the HHKB has a "crispness" and sound that I really think would make it a great choice if you're wanting the Topre experience.  It really was not bad at all getting used to the non-standard layout.
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #14 on: Wed, 14 August 2013, 13:58:02 »
HHKB if you want something radical and iconic, 660C if you want something cheaper but just as great. I found myself typing fine on the 660C coming from a 103U, so I don't think that matters. And RF actually follows IBM spacing spec EXACTLY, down to the 1/100th of a millimeter. It's crazy.
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline Thimplum
  • Master of all Ponies
« Reply #15 on: Wed, 14 August 2013, 15:00:06 »
All of them.
TP4 FOR ADMIN 2013
Offline TimIsABat
    • Instagram
« Reply #16 on: Wed, 14 August 2013, 20:29:15 »
« Reply #17 on: Wed, 14 August 2013, 20:41:27 »
All of them.
The moneys though
If it turns out you really like Topre, there isd a good chance you will end up owning all of them anyway.
Offline TimIsABat
    • Instagram
« Reply #18 on: Wed, 14 August 2013, 21:01:13 »
All of them.
The moneys though
Prolly lol. I might first start off with a Realforce, just cause I don't have a 87 keys board yet.
« Reply #19 on: Wed, 14 August 2013, 21:05:52 »
All of them.
The moneys though
Good idea.
It is a standard layour (more or less), so your Topre experience won't be overshadowed by struggling to find arrow keys and the like.
Offline TimIsABat
    • Instagram
« Reply #20 on: Wed, 14 August 2013, 21:17:32 »
All of them.
The moneys though
Good idea.
That is a good point. Gonna wait on getting it though because of other priorities, but if I have some left over money...well then XD.
Offline TimIsABat
    • Instagram
« Reply #21 on: Thu, 22 August 2013, 17:37:39 »
Okay. Bringing this topic up again because the ErgoDox groupbuy is up again, and I am debating to jump on that bandwagon.
All three boards come out to about the same price (over $250), so I really need to decide what to get. I won't have a job for a bit after next week (camp ends), so this needs to be a decision to make that will impact my typing experience for a while. If I were to go with the ErgoDox, I would get it with clears and do a spring swap to 62g.
My real concern is the weight of the springs fro the RF and the HHKB. I am wondering how light the 45g in comparison to 62g and mx reds on cherry switches. I've also read somewhere that the tactility of the switches wear away after use on 45g, which would defeat a good portion of reason in getting the HHKB. I love the portability and it would make a great substitute for my Poker X with ergoclears.
I am just wondering if it is really worth getting these two boards instead of an ergodox. I know they are completely different, but I need to really think about this investment.
Offline findingthelimit
  • Rawr
« Reply #22 on: Thu, 22 August 2013, 18:36:50 »
http://deskthority.net/news-reviews-f4/topre-introduces-new-type-heaven-keyboard-at-computex-t5903.html
I just saw this, I think it could be a good gateway from mx to topre! i've actually never used topre yet, and i can't afford it either as i'm trying to save up some money to buy an imac for my parents. this would probably be my first topre keyboard though, as long as the upcoming reviews don't give it too much crap!
Poker 2 reds, GH60 42g ergo clears
