Author Topic: Monoprice $10 off $30 purchase  (Read 1846 times)
Offline jameslr
« on: Wed, 14 August 2013, 10:18:39 »
http://www.monoprice.com/promotions/?id=10next_q3_2013_main&ref=cj
Good for any item. They have mechanical keyboards as well. I'm not sure of their quality, but they're cheap. Good for switch harvesting I suppose. I buy their cables all the time. They're good quality and very cheap.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
Re: Monoprice $10 off $30 purchase
« Reply #1 on: Wed, 14 August 2013, 10:24:12 »
Pretty sure Monoprice is a company that buys factory rejects and sells them at a marked down price. Like their IPS monitors usually have a stuck pixel or two. Most people are usually happy with them though.
(That was pertaining to their quality)
TOO BAD FOR YOU
              Phantom 62g MX Whites
Offline jameslr
« Reply #2 on: Wed, 14 August 2013, 10:41:58 »
Cool, thanks for the feedback. I have only ever bought cables from them. I considered getting a keyboard from them before I bought my QFR. Sort of glad I didn't though because i've read the reviews and they weren't positive.
