Author Topic: What is the different between these two keycaps?  (Read 4040 times)
Offline jonathanyu
« on: Thu, 15 August 2013, 01:13:03 »
I have found that there are two website that selling the GMK beige keyset. One is kbdmod, and the other one is originative.
http://kbdmod.com/product/detail.html?product_no=16&cate_no=12&display_group=1
https://www.originativeco.com/shop/keysets/product/84-classic-beige-keyset-blue-font
So, is there any different between them?
And also, is there any "F" and "J" match this set but not scooped?
Re: What is the different between these two keycaps?
« Reply #1 on: Thu, 15 August 2013, 01:23:37 »
They're exactly the same AFAIK, and no I don't think you can get any non-scooped maching F&J caps, and if you can they'll be original Cherry keycaps.
Offline jonathanyu
« Reply #2 on: Thu, 15 August 2013, 01:32:23 »
umm. I like that set, but i don't like scooped caps  :( is there any place that i can get individual F&J caps that is cherry height? The one from SP is a little bit shorter than cherry
« Reply #3 on: Thu, 15 August 2013, 01:43:11 »
No, there isn't anywhere you can get F&J caps made by GMK. You can only get them in the full sets from Sherry/kbdmod or from original Cherry doubleshot sets. I'm unsure whether there are any original Cherry sets with non-scooped F&J keys. If there are.. those are the only place you will find them. If not, then they do not exist.
Offline jonathanyu
« Reply #4 on: Thu, 15 August 2013, 01:52:47 »
maybe i should get a old cherry keyboard on ebay just for the caps.  :blank: or just use those scooped caps
Offline ebacho
« Reply #5 on: Thu, 15 August 2013, 03:15:35 »
The one place I know you can get non-scooped F&J's are those PBT dyesub or doubleshot alpha sets from vintage mx compatible typewriters (looking at my set here).  For examples, consult this thread http://geekhack.org/index.php?topic=36189.180
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Thu, 15 August 2013, 06:19:43 »
Nearly all Cherry and GMK sets will have scooped FJ keys. The most common exception to that are Desko BMOL (with center dots) and old Cherry based TA/Royal/etc typewriter (no homing indicators at all, just flat like every other letter). I will probably include alternate FJ with center dot like the numpad 5 in my GMK groupbuys. It won't be until September for the next buy starting though.
Offline esoomenona
  • Gnillort?
« Reply #7 on: Thu, 15 August 2013, 06:38:08 »
Can you include a scooped 5?
Offline jonathanyu
« Reply #8 on: Thu, 15 August 2013, 11:45:47 »
Missed your group buy  :( Wait for your next group buy
Since i am using TKL, scooped 5 isn't a big problem
