Author Topic: Question about kmac2  (Read 2420 times)
Offline Yuuki
« on: Thu, 15 August 2013, 04:37:10 »
Hello,
I've got a question about the kmac2.
http://kbdmod.com/product/detail.html?product_no=28&cate_no=4&display_group=1
Here, you can see a picture of what's called "kmac2 colored edition"
But i'm confused about the case : you can see one regular angled black case but also a red case with a design that that remind me of a 456 gt.
So my question is : what is this ? is this really a kmac2 ? (the red one)
Re: Question about kmac2
« Reply #1 on: Thu, 15 August 2013, 07:57:46 »
Think KMACs are usually anodized in Titanium or Black and the colored means its red. Don't see why it wouldn't be legit.
Offline Yuuki
« Reply #2 on: Thu, 15 August 2013, 08:11:44 »
No I mean the case design.
If you look at the link you can clearly see 2 different cases.
« Last Edit: Thu, 15 August 2013, 08:16:10 by Yuuki »
« Reply #3 on: Thu, 15 August 2013, 08:15:46 »
I also meant the cases. Unfortunately, the link doesn't work for me since I'm at work.
Offline Yuuki
« Reply #4 on: Thu, 15 August 2013, 08:20:45 »
31814-031816-1
I meant that difference between those two cases
Offline oTurtlez
  • DAT ZACKATTACK
  • Fo' Realforce
« Reply #5 on: Thu, 15 August 2013, 08:21:54 »
It's got options for a silver and a red case. It also seems to have a weird design to the back corners of the case.
I did NOT realize all those were one conjoined pic, my bad!
TOO BAD FOR YOU
              Phantom 62g MX Whites
« Reply #6 on: Thu, 15 August 2013, 08:30:33 »
So it looks like they changed the case design. If it's from KBDmod, I'm pretty sure it's legit. The picture of the black board is the older KMACs it seems: KMAC LE, 1.2, or 1.
Offline Yuuki
« Reply #7 on: Thu, 15 August 2013, 08:36:24 »
Ok thanks for the anwsers
I like that new design and it was a critical for me to pull the trigger or not :D
Offline aj-kun
« Reply #8 on: Sat, 17 August 2013, 01:50:10 »
looks like a handle to make it easier to lift off your table >.>
« Reply #9 on: Sat, 17 August 2013, 02:06:39 »
It's a new design of KMAC. KBDMod is 100% legit, and that is a real KMAC not some ripoff.
Offline Yuuki
« Reply #10 on: Sat, 17 August 2013, 05:40:56 »
yep it's confirmed.
Thanks for the answers.
Another noob question question : with a winkey configuration, what's the size of the mods and spacebar ?
« Reply #11 on: Sat, 17 August 2013, 05:50:29 »
yep it's confirmed.
Winkey - 1.25x mods, 6.25x spacebar
Winkeyless - 1.5x mods, 7x spacebar (1x winkey, or 1x blockers)
Offline Yuuki
« Reply #12 on: Sat, 17 August 2013, 05:54:58 »
Ok thank you very much
