Author Topic: Tex Beetle - fully programmable?  (Read 5107 times)
Offline Icte
« on: Fri, 16 August 2013, 11:43:09 »
Yes? No? Maybe?
Re: Tex Beetle - fully programmable?
« Reply #1 on: Fri, 16 August 2013, 11:43:33 »
No.
Offline Icte
« Reply #2 on: Fri, 16 August 2013, 11:50:46 »
D'oh.
Offline TheQsanity
  • SmallFry Lovin'
« Reply #3 on: Fri, 16 August 2013, 11:52:50 »
Omg
SmallFry! <3
Offline Icte
« Reply #5 on: Fri, 16 August 2013, 12:01:05 »
Technically every keyboard ever is made is fully programmable, usually however that stops at the factory.
Offline Icte
« Reply #6 on: Fri, 16 August 2013, 12:03:14 »
Yeah.. But I was thinking fully programmable as in "the KBT Pure Pro is fully programmable. And so is GH60" type of way and not where it stops lol.
« Reply #7 on: Fri, 16 August 2013, 12:05:27 »
You sure about the pure??
Just to clarify the boards I know are programmable are the GH60, the phantom, the poker 2 to some extent. And there are aftermarket controllers for some qfr/filco's. And then some of the older cherry boards obviously that have all those extra keys you can do things with.
And then like I said earlier some boards you might be able to drop in a teensy and work something up.
Offline Thimplum
  • Master of all Ponies
« Reply #8 on: Fri, 16 August 2013, 12:26:19 »
AHK?
TP4 FOR ADMIN 2013
« Reply #9 on: Fri, 16 August 2013, 12:34:35 »
AHK?
well that's an option.
Offline spiceBar
    • ChessTiger.com
« Reply #10 on: Fri, 16 August 2013, 14:23:24 »
KBT Pure: NOT programmable.
KBT Pure Pro: programmable. You can assign a macro to any [Fn]-[Key] or even to any [Key]. Warning: you cannot assign a macro to [Ctrl]-[Key] or [Shift]-[Key] or [Alt]-[Key]. However you can assign a macro to just [Ctrl] or just [Shift] or just [Alt] if you wish or really any [Key] except [Fn] and [Pn]. For example my Right-Shift does [Home] and my Right-Ctrl does [End].
The Pure and Pure Pro are really very different. They should not share the same name, it's very confusing.
Offline Icte
« Reply #11 on: Sat, 17 August 2013, 08:41:21 »
I did write KBT Pure Pro.. :P
Offline spiceBar
    • ChessTiger.com
« Reply #12 on: Sat, 17 August 2013, 10:11:25 »
I was answering to SpAmRaY.
Offline Hypersphere
« Reply #13 on: Sat, 17 August 2013, 15:31:55 »
I heard from Justin Wu, developer of the Tex Beetle, that there would be firmware available, but I do not know when, and I do not know what the firmware will do.
Offline justin.wu
  • * Commercial Vendor
  • Less is more
    • TEX
« Reply #14 on: Sat, 17 August 2013, 22:51:03 »
Hi !!
for now , I have say no , but might later we will release some firmware to upgrade , and we will develop software (or in web site ) , that can programmable standard layer and fn layer :)
Thanks for you question !!
Yes? No? Maybe?
make different
Offline Hypersphere
« Reply #15 on: Sun, 18 August 2013, 10:32:02 »
Thanks, Justin! Keep up your excellent work on the magnificent Beetle and new projects that are on your drawing board!
Offline justin.wu
  • Less is more
    • TEX
« Reply #16 on: Sun, 18 August 2013, 10:59:16 »
Thanks !!
Maybe 1 month , We will show new keyboard to you guys :)
make different
Offline Icte
« Reply #17 on: Mon, 19 August 2013, 02:31:09 »
Thanks !!
Woah, Justin Wu replied to my thread! AAAAAWESOME!!
