Author Topic: disassembling a filco?  (Read 3144 times)
Offline djones
« on: Tue, 11 November 2008, 22:00:47 »
How do you take apart a filco? I have a Japanese 10 key-less model which I spilled some liquids on and I want to on it up completely to dry. there's only one screw in the back which I removed but the damn thing refuses to open... is there a trick to pry it open?
Offline Chloe
  • Switch Kitten
« Reply #1 on: Fri, 14 November 2008, 11:26:53 »
It sounds like the case is a snap-together design. Sometimes there are subtle differences in the molding where the snaps are.
Are all Filco like this? Having screws makes it more serviceable in my opinion.
Offline Chloe
  • Switch Kitten
« Reply #2 on: Mon, 17 November 2008, 14:22:11 »
I found some pictures of the back of the FKBN87ML/EB. You could try removing the rubber feet, there might be screws underneath.
http://www.iqmore.idv.tw/archives/228/2
