Author Topic: Problem with Poker 2  (Read 1645 times)
Offline Little
« on: Sat, 17 August 2013, 17:23:29 »
My toggle mode on Poker 2 (Fn + Right shift) is not working anymore! The light on the left of the spacebar still goes on ad off but it makes no difference.
Has anyone experienced the same problem?
Offline justin.wu
  • * Commercial Vendor
  • Less is more
    • TEX
Re: Problem with Poker 2
« Reply #1 on: Sat, 17 August 2013, 22:54:01 »
Have you try reset this keyboard ??
If question still happen , I think you might ask distributor ...
make different
Offline Little
« Reply #2 on: Sun, 18 August 2013, 06:42:01 »
Do you know how to reset it?
« Reply #3 on: Sun, 18 August 2013, 14:46:05 »
It's in the manual
Restore to factory default
Press and hold FN + R, Spacebar left LED is flashing after 3 sec. Continue to hold FN + R until the Spacebar left LED flashes for 9 times will restore factory default
