Author Topic: Keycap Flocking Experiment  (Read 270154 times)
Re: Keycap Flocking Experiment
« Reply #200 on: Mon, 18 November 2013, 10:43:28 »
Here's one of the orange rayon flocked spacebars on my Ducky:
And this morning I flocked white nylon (slightly longer fibers) to see if there's a better "pile" on them.
^^ those bottom one's are snow caps!
That orange looks like it is waiting for some fingers to come take a nap.
Have I mentioned how insanely cool I think flocked key caps are!
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #201 on: Mon, 18 November 2013, 11:26:15 »
Thank you, sir.
How's the ganja cap?  :p
EDIT: *gasp* "SNOCAPS!"
« Last Edit: Mon, 18 November 2013, 11:30:49 by Krogenar »
Quote from: Samuel Adams
« Reply #202 on: Mon, 18 November 2013, 11:28:09 »
Thank you, sir.
I find myself touching it often, I actually use 'esc' quite a bit to cancel commands...
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #203 on: Mon, 18 November 2013, 13:05:21 »
They're not done curing completely, but after a few hours under the heat lamps, I've just brushed my finger over the new, nylon flocked keycaps --- very nice! The extra length did give them a better pile.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #204 on: Mon, 18 November 2013, 14:41:13 »
44792-044795-1
« Last Edit: Mon, 18 November 2013, 14:42:59 by Krogenar »
Offline stancato9
« Reply #205 on: Mon, 18 November 2013, 20:56:39 »
Poker 2 - MX Red
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #206 on: Tue, 19 November 2013, 06:26:38 »
That cap reminds me of Christmas time.
Thanks! I'm not sure how it looks on your monitor, but it's not as brilliant a white as seen in the photos. It's got a creamier sort of color.
Offline AGmurdercore
« Reply #207 on: Tue, 19 November 2013, 06:47:25 »
OMG these caps look sooooo awesome! Great job!
What the hell am I even doing
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #208 on: Tue, 19 November 2013, 06:49:41 »
Thanks! There are a limited number of BS spacebars available on techkeys.us -- also some MX stuff, single unit keys. I'm really, really liking the nylon. I'm doing a big run of these on Friday (warmest day this week remaining in NYC) and letting them cure over the weekend.  :thumb:
« Last Edit: Tue, 19 November 2013, 06:51:34 by Krogenar »
« Reply #209 on: Tue, 19 November 2013, 06:54:00 »
Yeah i saw them since day one on the website and i follow this thread since day one too. Sadly the total cost of the caps (+shipping) is way out of my range but i support you and i wish you good luck with this!
« Reply #210 on: Tue, 19 November 2013, 07:09:21 »
I would have a hard time resisting the urge to eat that one.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #211 on: Tue, 19 November 2013, 07:25:56 »
Here are better photos of the white, compared to unflocked white keycaps:
44888-044890-144892-2
« Reply #212 on: Tue, 19 November 2013, 07:44:24 »
Krog any thoughts on flocking fibers getting into switches?
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #213 on: Tue, 19 November 2013, 08:31:59 »
I've had no issues at all, and I've probably had more flocked keycaps/spacebars than anyone else. The flocking itself resembles (and behaves) like a very fine dust. Which means it cleans up just as dust would -- a vacuum.
I pass each key over a shop vac after a few days to suck off any excess fibers. This is after I gently tap off the excess that will fall off. The suction is so strong that I've actually had a few keys get sucked in -- they survive their adventure unharmed. The fibers don't really seem to come off. The hurdle I had to overcome was getting the undercoating to resist fingernail removal. That's been solved with roughening/cleaning the surface. I thought it was a priming issue -- it was not. Even then, removing the undercoating with a fingernail or a tool takes the flocking with it .
As for flocking coming off the keycaps during usage, I don't think it's a problem. Flocking fibers are used on automobiles, and are highly resistant to wear. Here'a video from a UK company that flocks automobiles.
https://www.facebook.com/photo.php?v=323931367737101&set=vb.121796507950589&type=3&theater
It's a video of a flocked car hood being washed.
Also, these fibers are very, very small -- your own body cruft, dandruff, is probably larger. So even if you did have an issue, a quick vacuum (probably what keyboard hobbyists already do normally) would remove any stray fibers. I haven't had an issue with fibers coming loose from keycaps. I even soaked one of my orange keycaps in undiluted turpentine and nothing came off. I removed flocking once from a metal keycap using turpentine, but it required a soak and brush, and another soaking.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #214 on: Thu, 21 November 2013, 15:00:39 »
Snowy!
45343-0
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #215 on: Wed, 22 January 2014, 08:09:39 »
Just so people know, if you want to give MX Snowball Flocked keycaps a try, this batch is available for sale here.
« Reply #216 on: Wed, 22 January 2014, 08:11:39 »
Krog...I...errr...misplaced that key I was going to send you to flock for me...when I find it I'll let you know.
Offline i3oilermaker
  • techkeys.us
    • TechKeys
« Reply #217 on: Wed, 22 January 2014, 08:38:02 »
These are awesome - I'm using one now and it feels so good!
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #218 on: Wed, 22 January 2014, 08:53:28 »
(stares at the postbox)
Sure, Ray, I get it.
I kid. No worries -- I'm not flocking around until the springtime anyway. The humidity and temperature are ALL WRONG right now. Also, I've got a few new idea on how to improve my flocking. I'm going to stop using skids altogether and suspend the caps in the air (chopstick painting, woohoo!) or figure out a way to use the skids, but keep the keycaps from resting on them. Also, I might try my hand at building a flocking cabinet, because the larger runs left me literally (proper use of the word, in this instance) covered in flocking fibers.
I highly recommend trying out the white flocked keycaps -- they're my best so far. Nylon fibers on those and slightly longer.
Which one are you using Boiler? The orange one, or the white one?
  • techkeys.us
    • TechKeys
« Reply #219 on: Wed, 22 January 2014, 13:13:41 »
I really like the white one
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #220 on: Mon, 05 May 2014, 06:37:56 »
I don't think I posted this, but I discovered two things about my latest nylon white flocked spacebars.
1. They get dirty. Finger oil, dust and dirt make them 'grey' or worse over time.
2. A little hand soap and some gentle washing will remove the discoloration!
63681-063683-1
  • techkeys.us
    • TechKeys
« Reply #221 on: Mon, 05 May 2014, 09:08:01 »
Good to know!  I've been using mine for a few months now and there is a little dirt accumulation on the left side where my left thumb hits it...I was actually kinda liking the discoloration, but I might try this out.
I can't say enough how much I love a fuzzy spacebar under my thumb!
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #222 on: Mon, 05 May 2014, 09:15:15 »
I was just amazed at how utterly filthy my thumb gets. LOL, glad you're still enjoying the spacebar. I've got to get started on a new enclosure, something a bit more permanent.
