Author Topic: Where To Buy Cherry MX Clear Switches  (Read 6689 times)
Offline terran5992
  • One With The Cup Rubber
« on: Sun, 18 August 2013, 06:36:37 »
As titled, i am looking to change the keys on my poker to cherry mx clears but im having problems finding the switches
Offline TheQsanity
  • SmallFry Lovin'
Re: Where To Buy Cherry MX Clear Switches
« Reply #2 on: Sun, 18 August 2013, 07:09:04 »
That is marked up way to much. Wait for a group buy. Or try to find a board on eBay with them and salvage them.
SmallFry! <3
« Reply #3 on: Sun, 18 August 2013, 07:14:43 »
Mouser should have some for a decent price if you don't want to wait for a GB
« Reply #4 on: Sun, 18 August 2013, 07:43:11 »
We really ought to do another switch groupbuy. DT > GH on that front.
« Reply #5 on: Sun, 18 August 2013, 08:48:23 »
7bit's  group buy is still ongoing
Offline yasuo
  • spanengan puyeng newbie
« Reply #6 on: Sun, 18 August 2013, 08:56:36 »
yes,7bit also cheaper
Logitech MK220 Colemak DH
« Reply #7 on: Sun, 18 August 2013, 09:48:03 »
I recommend 7bit.
I would also recommend to also order a tactile grey switch for the Space Bar. That is something that you can get from 7bit but not from the others.
Offline terran5992
« Reply #8 on: Sun, 18 August 2013, 09:49:49 »
Could a kind soul please throw me the link?
Offline yasuo
« Reply #10 on: Sun, 18 August 2013, 09:54:26 »
« Last Edit: Sun, 18 August 2013, 09:56:58 by yasuo »
Offline terran5992
