Author Topic: Keyboard lubing, optional or necessary?  (Read 2943 times)
Offline Obakemono
« on: Sun, 18 August 2013, 08:43:59 »
Hi!
I'm very new to the keyboards world, and i'm gathering as much info as i can, but about keyboard lubing i can't find any hint on this exact matter.
I can see why lubing the stabilizers might be necessary, but about lubing the switches i need someone to clarify me if it is necessary to the proper use and maintenance of the keyboard or if it is optionally done only to alter the behavior of the switches.
Re: Keyboard lubing, optional or necessary?
« Reply #1 on: Sun, 18 August 2013, 09:02:36 »
Hi!
It's all personal preference.
Offline Jocelyn
  • 조셀린
« Reply #2 on: Sun, 18 August 2013, 09:07:40 »
This^ though I could personally never type on non lubed switches.
Offline KeyLord
« Reply #3 on: Sun, 18 August 2013, 09:35:01 »
Here is an imgur album that ripster made on switch lubing. It's pretty comprehensive.
I haven't lubed my switches yet... I would have thought it is more of a maintenance thing to do, as the lube that is already on them begins to wear out after extended amounts of use.
http://imgur.com/a/lhLqo
Offline TheQsanity
  • SmallFry Lovin'
« Reply #4 on: Sun, 18 August 2013, 09:50:24 »
It doesn't really matter. I think you should leave tactile switches dry to maximize tactility. Unless you want your browns to feel more like reds :p
SmallFry! <3
Offline Obakemono
« Reply #5 on: Sun, 18 August 2013, 10:01:27 »
Crystal clear!
Thank you!  :D
Offline jabar
« Reply #6 on: Sun, 18 August 2013, 10:25:17 »
never lubed any of my Cherry keyboards
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Danule
« Reply #7 on: Sun, 18 August 2013, 18:31:59 »
Have tried lubed switches yet. But browns over time become smoother / less gritty so im not sure if its really nessisary if you take the time to break the switches.
45g Brown Brown Blue
« Reply #8 on: Sun, 18 August 2013, 18:54:00 »
Cherry MX Clears should be lubed. Vintage blacks and blues don't need to be. Whites are already lubed from the factory.
Other than that, it is a matter of taste. Some feel that reds and blacks have to be lubed. Other people don't.
Offline TimIsABat
  • MX Clears are life
    • Instagram
« Reply #9 on: Sun, 18 August 2013, 22:42:51 »
I really want to lube my ergoclears. Might try to do so after I try fixing my poker.
Leopold FC660M MX Reds | Poker X 62g  Ergoclear modded and plate modded (out of comission) | IBM Model M 1391401 | Dell AT101 | Compaq RT101 | HHKB Pro 2 | WASD CODE TKL MX Clears
Avid vape collector and advocate. I used to work at to renowned vape shops here in New Jersey. Message me for any vape related questions.
Main driver : WASD CODE TKL MX Clear
Offline Larken
« Reply #10 on: Mon, 19 August 2013, 05:58:43 »
optional, not necessary, but highly recommended.
not for proper use/maintenance, but yes for altering the feel of the switch. Intense smoothness, if that makes sense.
| Ergodox #1 | Ergodox #2 |
« Reply #11 on: Mon, 19 August 2013, 06:42:25 »
Not a good idea for clicky switches as it kills the clicky-ness. Really good idea for MX Blacks. Just tried it over the weekend at Keycon and lubed Blacks are amazing.
