Author Topic: Cooler Master Storm Quickfire TK double zero '00' software bug?  (Read 6275 times)
Offline zippox
« on: Mon, 19 August 2013, 07:22:07 »
I'd like to take a quick poll for those of you that own this keyboard.
Press any key or number and quickly follow that with the '00' button.  On my keyboard when I do this it will repeat that first key that I pressed.
Example:
I will press r followed closely by '00'.  That's it. Here is what happens:
r00r
If I were to speculate, I think that my keyboard is fine and the problem lies in the software. I bet when '00' is pressed it calls some sort of repeatLastKey() function and the 'r' gets put into the function somehow.
Offline kmiller8
  •  Post Reporting Timeout
  • Who is that kmiller8 guy?
Re: Cooler Master Storm Quickfire TK double zero '00' software bug?
« Reply #1 on: Mon, 19 August 2013, 07:24:18 »
I have this same problem, the way I've found around it is to hold the 00 key a little bit longer instead of just tapping it.
Offline zippox
« Reply #2 on: Mon, 19 August 2013, 07:27:02 »
Well I'm glad I asked before spending the money to ship my keyboard back to CM and getting a replacement. Nice job software testers. Nice job...
I asked CM about this and they aren't willing to do a firmware or software upgrade.
Offline kmiller8
« Reply #3 on: Mon, 19 August 2013, 07:41:12 »
They might have fixed it with the new firmware that was mentioned when I brought up other problems with the TK.
I really like this layout, but man this keyboard has had more problems than it should :/
Offline Neal
  • Skype: iNewbcake
« Reply #4 on: Mon, 19 August 2013, 07:49:01 »
Time to switch to Phantom :)
Offline kmiller8
« Reply #5 on: Mon, 19 August 2013, 08:10:40 »
yes, because the phantom has a TK layout.
Offline Neal
  • Skype: iNewbcake
« Reply #6 on: Mon, 19 August 2013, 15:10:51 »
Pretty sure it is supported? Or am I being silly?
Offline remlap
« Reply #7 on: Mon, 19 August 2013, 15:35:01 »
UK ISO model has this bug too.
Offline kmiller8
« Reply #8 on: Mon, 19 August 2013, 15:41:49 »
it has a faux-TK with just the numbers, no enter.
Offline Neal
  • Skype: iNewbcake
« Reply #9 on: Mon, 19 August 2013, 15:50:08 »
Ooooh, right! my bad.
Offline Thimplum
  • Master of all Ponies
« Reply #10 on: Mon, 19 August 2013, 16:18:58 »
How practical...
TP4 FOR ADMIN 2013
