Author Topic: FYI, Ducky with Clear....  (Read 3990 times)
Offline PadawanGeek
« on: Mon, 19 August 2013, 08:47:24 »
Just a headsup guys, seems Ducky's releasing a Ducky with Cherry Clear switch and PBT key caps (looks like white LED back light)....
I'm so getting it!
Re: FYI, Ducky with Clear....
« Reply #1 on: Mon, 19 August 2013, 08:50:37 »
I was hoping they hadn't given up on releasing 'new' boards with clears!!
of course that kind of looks like a shine 2.
« Reply #2 on: Mon, 19 August 2013, 08:52:05 »
Are you sure those are PBT? They look like the standard ABS caps that the Ducky boards have. Do you have a link or another picture for this information?
Offline GeeGee
  • ㅈ ㅈ
« Reply #3 on: Mon, 19 August 2013, 08:58:31 »
Will MK have these in stock?
Ducky Shine 2 with Blues
Poker 2 with Reds
KMAC Korean Custom with Clears
ReΛlforce 87u 55g
456GT
Offline PadawanGeek
« Reply #4 on: Mon, 19 August 2013, 09:00:48 »
The local distributer posted this pic, and promised that it'd be out soon....I asked him to reserve one for me. It's not cheap, more pricey than a regular Ducky Shine KB, whether it's Shine 2 or 3, I can't say. If I get it soon, I will post some pics and my impressions....
Offline Danule
« Reply #5 on: Mon, 19 August 2013, 09:04:05 »
i bet those are ABS :)
45g Brown Brown Blue
Offline Moosecraft
  • HHKB Pro
« Reply #6 on: Mon, 19 August 2013, 09:08:39 »
Those look like ABS caps, PBT is not as glossy from what I've seen.
« Reply #7 on: Mon, 19 August 2013, 09:21:43 »
I'm pretty sure that is a ducky shine 2 original promo photo as can be seen here also
http://tigerimports.net/sunshop/index.php?l=product_detail&p=13621
32306-0
Offline infiniti
  • I <3 KB
  • Bob was here
« Reply #8 on: Mon, 19 August 2013, 09:28:31 »
Found a post on facebook by Ducky Keyboard Singapore: https://www.facebook.com/photo.php?fbid=544436068956167&set=a.517338344999273.1073741828.517337508332690
Ducky Clear switch with PBT keycap ! -Coming soon - $219
I assume that's Singapore dollars...so that's about US$171.
Anyway, they really look like the standard shine caps.  Could the paint/coating be the same but the base plastic be translucent PBT?
Offline PadawanGeek
« Reply #9 on: Mon, 19 August 2013, 09:40:25 »
The local distributor in my neck of the woods has agreed to keep one piece aside for me, seems there is some interest in rare switch types. I'm hoping it comes soon, then I can pick up both the YOTS and the Clear.......
Edit - BTW, there's also a Ducky Rubber Duck Edition expected out in October in very, very limited quantity. It has yellow case with yellow PBT key caps....though I've heard that it's available with Cherry Red, yeah, a downer, right?
« Last Edit: Mon, 19 August 2013, 09:43:19 by PadawanGeek »
Offline jameslr
« Reply #10 on: Mon, 19 August 2013, 09:49:18 »
The Wasd V2 Code with white backlights and MX clears will be out in a few days per their most recent blog post on their site. I think that would be a good TKL or TK alternative to the Ducky in the short term as the Ducky is probably still months away.
« Last Edit: Mon, 19 August 2013, 09:52:30 by jameslr »
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
« Reply #11 on: Mon, 19 August 2013, 09:53:06 »
The Wasd V2 Code with white backlights and MX clears will be out in a few days per their most recent blog post on their site. I think that would be a good TKL alternative to the Ducky in the short term as the Ducky is probably still months away. Unless of course you need the tenkey.
I'm not sure there has been or will ever be a ducky TKL with clears....or did I miss something?
Offline jameslr
« Reply #12 on: Mon, 19 August 2013, 09:56:12 »
No, I don't think you did. To my knowledge there has never been a Ducky TKL with clears. I think the general sentiment was "ducky board with MX clears" and several people want TKL versions. This is why I was pointing out the upcoming Wasd V2 code which comes in TKL and TK sizes with Cherry MX clears and backlights.
Offline Danule
« Reply #13 on: Mon, 19 August 2013, 09:58:20 »
thats weird, what is the point of making the keycap PBT if they are putting a coating on it that will wear away anyway... the whole point of pbt is that the plastic is durable.
« Reply #14 on: Mon, 19 August 2013, 10:04:12 »
Gotcha! Occasionally ducky does a very limited release so I thought maybe they did or were going to.
Offline Photoelectric
« Reply #15 on: Mon, 19 August 2013, 10:47:41 »
Interesting, this looks exactly like my Ducky Shine II with Clears (minus the Asian legends).
« Reply #16 on: Mon, 19 August 2013, 10:49:11 »
Yeah see the pic I posted above of a Ducky Shine II promo pic....I'm thinking they just reused a promo pic.
