Author Topic: FlashGet G600 MX Cherry Blacks  (Read 35230 times)
Offline ITzNybble
  • Formerly curro123083
  • Nibble or Nybble either way it sounds delicious!
Re: FlashGet G600 MX Cherry Blacks
« Reply #50 on: Thu, 12 December 2013, 10:28:21 »
I do not have it anymore, sowry :(
WASD V1 Custom - MX Blue
Custom Miami QFR - MX Green
Handwired Redox-Manuform - Box Pink/Box Navy
KBD67 MKII PolyCarbonate - Gateron CJ
« Reply #51 on: Thu, 12 December 2013, 16:23:52 »
So I went ahead and got a G600 as I wanted an affordable keyboard I could take apart and play with.  Here are some pictures of what greeted me on removing the underside:
The PCB
Controller:
Solder close up:
Did it actually work?
Offline synerr
« Reply #52 on: Thu, 12 December 2013, 17:13:44 »
Yes it did, but won't any more.  Harvested the keys for a 60% project and have some ideas for the metal chassis.
Press any key to continue, any other key to quit.
« Reply #53 on: Thu, 12 December 2013, 17:22:10 »
Fair enough.
I wonder how many more left the factory like that.
Offline tgujay
« Reply #54 on: Thu, 12 December 2013, 20:27:42 »
Fair enough.
Probably all of them.
Gotta collect them all
Offline MAR82
  • Keyboard Addict
« Reply #55 on: Sun, 26 October 2014, 10:04:18 »
The PCB
Controller:
Solder close up:
Holes for LED's!  does the software support lighting?
Well there are LEDs on a few keys...so technically you should be able to add your own...might need some additional set up though, resistors and such...
Usually on boards where there are only LED's on the mods like the Quickfire there are no LED through holes for the rest of the switches on the PCB, in that picture there are LED through holes for all of the switches.  This leads to believe this board uses the same PCB as a backlit model, like the Poker 2, and there are probably hot keys for adjusting the LED's once installed.  The D numbers next to the switches are for the diodes, I'm assuming the L numbers are for the corresponding resistors for LED's.
I concur with your thoughts!
So has anyone tried putting LEDs on this board?
I have a one and was thinking of added some LEDs, However I'm not sure if and what resistors I need, and what would be the hot keys to turn it the LEDs on.
