Author Topic: ANSI Model F AT mod - 8.25.2013  (Read 29474 times)
Offline Giorgio
Re: ANSI Model F AT mod - 8.25.2013
« Reply #50 on: Sun, 17 June 2018, 18:08:11 »
oh yuss!
I also lighted the spacebar so it is more uniform! Now just a Soarers to get the number pad working how I want to without an AHK program.
I imagine that you ligthened the spacebar by bending the wire. Can you remember how much did you bend it? thanks
Offline Ruediger87
« Reply #51 on: Sat, 07 December 2019, 08:12:01 »
oh yuss!
Apologies for rehashing this thread years later, but how exactly did you lighten the space bar? Was it the wire bending trick, or did you chop off a bit of the black plastic holding it in place? :/
