Author Topic: Comfort keyboard mounting system review - but only in pictures  (Read 4362 times)
Offline hoggy
  • * Moderator
« on: Mon, 19 August 2013, 15:50:07 »
Offline Thimplum
  • Master of all Ponies
Re: Comfort keyboard mounting system review - but only in pictures
« Reply #1 on: Mon, 19 August 2013, 16:23:10 »
In words, what opine you?
Key feel?
Comfort?
TP4 FOR ADMIN 2013
Offline kurplop
  • THE HERO WE DON'T DESERVE
« Reply #2 on: Mon, 19 August 2013, 17:15:25 »
hoggy,
Thank you for your contributions to keyboard ergonomic knowledge.
I don't think I'd want to meet the creature that would be comfortable using that last position.
Offline hoggy
  • * Moderator
« Reply #3 on: Mon, 19 August 2013, 23:50:58 »
My original thought was that I got a Friday afternoon special. Comfort haven't replied to my email...
The stand looks good, but slides into the keyboard in the wrong direction. I'm not impressed frankly.
It could be fixed easily by gluing a stopper to the underside of the board once the stand is inserted.
If you need a keyboard with very low activation force, then maybe. Otherwise avoid.
Offline hoggy
  • * Moderator
« Reply #4 on: Mon, 19 August 2013, 23:56:01 »
I should mention that I didn't buy this new, so it's fair enough that comfort haven't returned my email.
Offline hoggy
  • * Moderator
« Reply #5 on: Thu, 22 August 2013, 15:00:13 »
For some reason, the photos reminded me of the Toadies from Chorton and the Wheelies.
Sorry for the off-topic post.
Offline Thimplum
« Reply #6 on: Fri, 23 August 2013, 18:43:29 »
Can you be off topic in your own thread?
TP4 FOR ADMIN 2013
Offline RabRhee
« Reply #7 on: Fri, 23 August 2013, 19:54:21 »
Can the rails on the underside of the keyboards be unbolted and rotated 90 degrees? I see what looks like allen bolts, but it seems like the holes wouldn't let you rotate them. Its the only thing that looks like it could have been a mistake though.
-Life is good-          Crafting: |  Keychains |  More.   .Keychains | Crowdsource Key | Budget Keycap Board |
Offline hoggy
  • * Moderator
« Reply #8 on: Sat, 24 August 2013, 01:46:23 »
They don't want to budge.  They look like allen bolts in the picture, but look smooth in person.  I suspect they are press-fit.  The 2 pieces of protruding plastic (looks like a : in the picture) are definitely there to stay.
In fact looking at this picture (from the fen-tek industries site)
It's pretty clear that it's not just my unit.
It's a shame.  The mounting system is simple, robust, allows infinite control over splay, and
I give up, perhaps the keyboard meant to slide off the stand... :(
