Author Topic: Need help with poker 2 programmable function to remap keys!  (Read 2039 times)
Offline singaporean123
  • I like keycaps and I cannot lie
« on: Tue, 20 August 2013, 02:47:47 »
After contemplating for over a year I finally got a poker 2.
I tried to remap my windows key but it doesn't work.
I first accessed the function by clicking FN + right control.
LED flashes, and I press the windows key, flashing stops.
Pressed function key.
Pressed Pn key.
LED flash starts.
Press fn+ right control.
yet windows key still activates my metro ui (win 8 user here).
Help please!
Offline iAmAhab
  • Established member
Re: Need help with poker 2 programmable function to remap keys!
« Reply #1 on: Tue, 20 August 2013, 03:37:43 »
It's not possible to do that through programing on the Poker II. All the keys you program have to be invoked through the PN-button.
So in your case PN+WIN will invoke FN now, luckily you can achieve what you want through other means. Turn your keyboard up side down
and set SW3 to on, now the WIN-button will act like FN.
« Reply #2 on: Tue, 20 August 2013, 04:00:15 »
thanks a lot, that just saved me so much inconvenience!!!@! :thumb:
Offline laffindude
« Reply #3 on: Tue, 20 August 2013, 08:53:40 »
Dip switch 3.
