Author Topic: Quick inquiry about the Corsair Vengeance K60 and the CM Quickfire Pro  (Read 1508 times)
Offline distincthd
Is the Corsair Vengeance K60 Cherry MX Switches PCB mounted? Like would i have to unsolder them if i wanted to mod them? Same thing goes for the Coolermaster Quickfire Pro, are they PCB Mounted? And likewise, would i have to unsolder them if I wanted to mod the switches to change the switch types?
Re: Quick inquiry about the Corsair Vengeance K60 and the CM Quickfire Pro
« Reply #1 on: Tue, 20 August 2013, 09:09:14 »
They are both plate mounted and require desoldering if you want to change switch types :)
Offline distincthd
« Reply #2 on: Tue, 20 August 2013, 09:10:02 »
Dang but ultra fast reply dude thanks :)
