Author Topic: Solution To Turn Off MacBook's Built-in Keyboard?  (Read 21893 times)
Offline melt
    • check out my Instagram!
« on: Tue, 20 August 2013, 19:00:55 »
I'm trying to find a mac app that will allow me to disable the inbuilt keyboard on my macbook so I can place another keyboard over it.  Any of you peeps know what a good solution would be?  I tried the keyboard cleaner app, but it turns off the usb connected keyboard as well, bummer... let me know, thanks!!! ;D
Offline esoomenona
  • Gnillort?
Re: Solution To Turn Off MacBook's Built-in Keyboard?
« Reply #1 on: Tue, 20 August 2013, 19:03:20 »
I've searched for something like this on PC here before, and I don't believe it's possible... aside from opening it and popping the ribbon cable.
Offline vivalarevolución
« Reply #3 on: Tue, 20 August 2013, 19:07:09 »
KeyRemap4Macbook might have something for you.  If you are unsure if it will work, I would email the contact person.  He is very helpful.
https://pqrs.org/macosx/keyremap4macbook/
Offline melt
« Reply #4 on: Tue, 20 August 2013, 19:49:26 »
if worst comes to worst, I'm just going to have to deribbonize, haha! who needs chiclets anyways?
Maybe: http://forums.macrumors.com/showthread.php?t=433407
Thanks for that one.  :thumb:  I've tried that in the past but couldn't quite get it to work  :(
thanks, will check this out, like, nowwwwww  :thumb: :D
Offline melt
« Reply #5 on: Tue, 20 August 2013, 19:59:03 »
There's also this solution...
http://shop.bird-electron.co.jp/shopdetail/005006000006/013/000/order/
which I have now, but it covers the trackpad haha.  Don't like using a mouse on the run
Offline esoomenona
  • Gnillort?
« Reply #6 on: Tue, 20 August 2013, 20:08:05 »
This is the solution. We just need to find someone who can make them about six inches wide instead of the whole thing!
« Reply #7 on: Tue, 20 August 2013, 20:17:57 »
Looks like a bit of glass or plastic with rounded corners and little rubber feet in the corners.
Surely someone here could make one?
Offline esoomenona
  • Gnillort?
« Reply #8 on: Tue, 20 August 2013, 20:31:26 »
Bird Electron makes items out of what I take to be high quality acrylic. I'm sure someone here could make something similar with hopefully a similar quality, while adding custom dimensions.
« Reply #9 on: Thu, 22 August 2013, 10:18:14 »
There might be some way to work out a solution where you cut one wire in the ribbon (ground, let's say) that would disable the whole thing.  Then solder that to a tiny switch that you can mount somewhere in the case so you can disable and enable the built in keyboard on the fly.  I don't know how elegant you could make it, or even if it'd be possible.  But it's a thought.
Offline Quardah
    • DeliTech
« Reply #10 on: Thu, 22 August 2013, 10:19:17 »
Sledgehammer.
Tested and working fine.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline melt
« Reply #11 on: Thu, 22 August 2013, 12:04:28 »
thanks for all your input, fellas!  found  an awesome solution for an 11 inch macbook air.... use a keycool 84, like so......  :p
the rubber padding feet thing's just exactly miss the keys, yesssss
Offline Quardah
    • DeliTech
« Reply #12 on: Thu, 22 August 2013, 12:33:35 »
Holy ****ing christ this is a storm of color lol
Pretty neat altought a little Not-Straight. No offence intended lol
Poker II - Brown MX
Offline melt
« Reply #13 on: Thu, 22 August 2013, 13:22:44 »
yeah, it could be considered quite girly, though I don't mind as I get all the ho's haha! :p
Offline Quardah
    • DeliTech
« Reply #14 on: Thu, 22 August 2013, 13:42:59 »
Ballers ain't giving no fukks.
Poker II - Brown MX
Offline davkol
  •  Post Editing Timeout
« Reply #15 on: Thu, 22 August 2013, 14:04:04 »
Please, repost to the Unicorn Vomit Thread. You're a clear winner, especially with the additional lips stickers.
Offline melt
« Reply #16 on: Thu, 22 August 2013, 14:12:46 »
haha, those lip stickers were coming off cause i stuck em on the pink decal, so i just peel them off.  kinda a sad moment right now haha
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #17 on: Thu, 22 August 2013, 14:19:34 »
You can do this with the Matias Laptop/Mini keyboards, too. IIRC they were designed to be used on top of Macbooks. Mine works on top of 13" Macbook, 15" Macbook Pro and 14" Thinkpad.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
Offline frenchtoasters
« Reply #18 on: Tue, 13 January 2015, 08:51:23 »
Not sure if anyone else has tried it but Karabiner has an option "Disable an internal keyboard while external keyboards are connected" it works pretty well ive found. There is a bug every now and then when you unplug and replug the keyboard a few times, if you like me switching between computers, neither keyboard will work after doing that a few times forcing a restart to fix.
Offline the_marsbar
« Reply #19 on: Thu, 25 February 2016, 06:46:44 »
An A4 sheet of acrylic (I used a 2 mm thick one) will make two quite nice plates, each will fit a HHKB very nicely. It's a nice, cheap way of taking care of the keys on your laptop, and making sure that the keyboard has a solid base.
I only have a HHKB Pro 2 Type-S, but I'm sure a similar technique could be used for keyboards of other sizes.
Offline Marizen
« Reply #20 on: Fri, 26 February 2016, 12:36:50 »
You don't.
You may only do what Apple says you can do.
« Reply #21 on: Fri, 26 February 2016, 13:47:46 »
You can do a partial disable that turns your keyboard into a mouse.
https://discussions.apple.com/thread/3796547?tstart=0
Offline the_marsbar
« Reply #22 on: Sat, 05 March 2016, 07:29:43 »
So I was actually a bit annoyed by the solution with the acrylic sheet. First of all, if you're stressing the machine, some of the heat is supposed to exit through the keyboard. Second, the acrylic sheet is slightly visible from the front and the sides.
What I ended up doing instead was to use some spare 3M helicopter tape that I had, with which I built some "feet" to put under the keyboard (basically it's just four layers of the tape on top of each other. This has the added bonus of providing a more stable base of the keyboard, because the tape feels a bit like rubber on the surface.
I'm happy now, I think. No need to disable the internal keyboard, and no need to bring the acrylic sheet everywhere I go.
I hope this is useful to other people too.
Offline phosphoric
« Reply #23 on: Mon, 07 March 2016, 17:35:25 »
+1 karabiner has worked like a charm for me. i havent encountered this bug, but i've found that waking my laptop from sleep with an external keyboard rarely ever works
Let's get this straight. There is nothing cool about keyboards we're all lame as fk.
speak for yourself
Offline appleonama
  • Trollo en USA
Offline the_marsbar
« Reply #25 on: Wed, 09 March 2016, 03:00:29 »
Besides your cat being able to sit on your laptop without it accidentally sending e-mails to you boss, I don't see any reason to disable the built-in keyboard. IMO it's much better to avoid the HHKB touching the keys (with the risk of breaking something), which is really just a matter of adding a couple of feet to the back of the keyboard (at the sides).
