Author Topic: Looking for a mechanical keyboard with a Mac layout, with no number pad  (Read 9977 times)
Offline dublinus
I've been looking around for a while for a mechanical keyboard. I have found some that *almost* meet my criteria, but fall short one way or another.
What I'd like in a keyboard is this:
- No number pad
- Mac layout
- Cherry MX Brown switches
- Preferably backlit
- Preferably wireless
After doing quite a bit of digging around, I found that the limiting factor is the Mac layout. Very few companies offer that option. Razer is one such company, but the keyboards they offer with the Mac layout have a really big number pad, which for me is a huge waste of space.
Does anyone know of a better keyboard?
Re: Looking for a mechanical keyboard with a Mac layout, with no number pad
« Reply #1 on: Wed, 21 August 2013, 01:59:56 »
Welcome to Geekhack!
Mac layout is over-rated ;)
I have a Mac and use PC layout keyboards just fine (including an IBM Model M, although that lacks the Option key).  You only need to swap Win and Alt to get the Command key back to where it should be.
Not MX brown, but try Matias: http://matias.ca/products/
If you don't mind PC layout, try Ducky Shine TKL.
Offline justin.wu
  • * Commercial Vendor
  • Less is more
    • TEX
« Reply #2 on: Wed, 21 August 2013, 03:08:07 »
How about this one layout ??
- No number pad
- Mac layout
make different
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #3 on: Wed, 21 August 2013, 04:59:59 »
I also use PC layout boards with my Macs. You can add KeyRemap4Macbook to get media and other functions.
OTOH, the PC keyboard I'm currently using happens to be a Mini Quiet Pro, which has the media stuff built in. The media keys from the PC version of the MQP are also recognized on the Macs, and even Ubuntu.
If you like MX browns you'd probably be very happy with the Matias quiet switches. They are nicely tactile though a bit heavier than browns.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
Offline dublinus
« Reply #4 on: Wed, 21 August 2013, 07:47:46 »
Thanks for the help guys! I'm leaning towards a Matias right now.
Offline pixel5
    • pixel5
« Reply #5 on: Wed, 21 August 2013, 07:50:30 »
No one has mentioned the WASD v2 TKL? It's got a dip switch on the back to switch between standard and mac layouts.
http://www.wasdkeyboards.com/index.php/wasd-v2-87-key-custom-mechanical-keyboard.html
If thats the route you want to go, I recommend getting the barebones version and buying a nice set of keycaps, a combo such as this:
http://www.wasdkeyboards.com/index.php/wasd-v2-87-key-barebones-mechanical-keyboard.html
and
http://www.vendio.com/stores/E-sports-Gaming-equipments/item/pbt-key-caps/104-105-pbt-black-on-white-key/lid=19240210
WASD's keycaps are not worth $50 a set, they are very thin ABS.
« Last Edit: Wed, 21 August 2013, 07:53:17 by pixel5 »
Poker II
Quickfire Rapid
BUY MY CRAP
Offline IvanIvanovich
  • Mr. Silk Underwear
« Reply #6 on: Wed, 21 August 2013, 09:57:13 »
DSI modular numpad is a module that is optional that can attach either side.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #7 on: Wed, 21 August 2013, 10:40:39 »
The mac layout isn't that difficult to match given that you just need to swap a couple of keys and many boards even offer it via a dip switch. The hard part is that you want it wireless and there just aren't that many mechanical keyboards that are wireless.
I'm a big fan of the compact layout, so a Poker 2 would be a nice option. The current models do not have backlighting, but there is support on the board for it. You'd just have to solder (of find someone to do it for you) the LEDs in for you. MechanicalKeyboards.com has one with MX-Brown switches.
They are also a reseller for Matias as well.
Offline nsrexler
« Reply #8 on: Wed, 21 August 2013, 15:23:27 »
The WASD V2 and Ducky DK9008 and DK90087 all have a DIP switch on the underside which allows you to swap the position of the "Windows" and "Alt" keys, essentially creating a Mac layout.
Offline MJ45
  • HHKB Pro
« Reply #9 on: Wed, 21 August 2013, 17:41:43 »
The HHKB Pro2 is a very Mac-Unix compatible but expensive.
Offline Obakemono
« Reply #10 on: Wed, 21 August 2013, 17:44:09 »
I'm using a non-mac keyboard with my mac since a couple of days and it's pretty easy to get used to.
I use some key shortcuts and i'm nor missing nothing for now
« Reply #11 on: Wed, 21 August 2013, 17:45:02 »
But not exactly Mac layout, definitely not MX brown, not backlit, and not wireless, so it fulfills almost none of the OP requirements.
Offline Chrontius
« Reply #12 on: Wed, 21 August 2013, 22:51:17 »
I've got almost the same wish list as the OP, so I'll share my experience.
TL;DR:  I use a Matias Quiet Pro, full size.  It's glorious.  Alps switches feel good.
My first mechanical was the DSI SMK-88, a compact tenkeyless… in cherry black.  I found the linear keys suboptimal, but it offers the layout you like, the size you like, and that probably ought to count for a lot.
My next carefully considered keyboard was a Matias Tactile Pro Mk.1.  (I also rehabbed a Das Mk.1 but that was a side project)  It was great - I loved the layout, loved the softer feeling of the Alps than Cherries, and loved the system hotkeys.  I found the "optimizer" secondary and tertiary key printing really nice and really useful - did you know that "alt ;" produces an ellipsis?  I didn't either.
The closest to your gold standard is probably the Matias Laptop Pro.  It's a bluetooth mechanical tenkeyless mac keyboard that feels a lot like heavy Browns but is, alas, not backlit - but I asked Matias for something like that, and they said they'd consider it.  If you'd be so good as to email them, along with a couple dozen more mac fans, we'll probably get one.  But I'd get the one on offer now, it's a really nice board.
Offline tjcaustin
  • King Klaxon
    • Buy stuff
« Reply #13 on: Wed, 21 August 2013, 22:52:45 »
I have a white matias tactile mini for sale if you're interested.  PM me
Offline dublinus
« Reply #14 on: Thu, 22 August 2013, 13:59:45 »
Wow, I've gotten some really helpful replies. Thanks everyone!
Kind of torn between some of the options. The Matias and WASD both look pretty good. I'm just very impressed by WASD's customization.
Anyways, thanks for your help!
« Reply #15 on: Thu, 22 August 2013, 21:36:22 »
Let us know which one you eventually get, and what you think of it.
Tip: if you hang around here long enough, you will end up getting both anyway.
