Author Topic: Replacing/Repairing ALPS key switches  (Read 3551 times)
Offline morpheus
« on: Wed, 21 August 2013, 06:50:36 »
Hi there,
I dunno if this topic has been explored already, I'm assuming it has, but here's another thread....
Recently, I bought a used Alps board, but a couple of the key are non-responsive and won't work when I press down on them.
I'm guessing the switches are broken and in need of repair. The problem is I've never replaced or repaired key switches in my life and am afraid of doing so because I might break it even more.
Can somebody please give me some advice on what to do here?
Thanks you guys are the best  :thumb:
Offline BlueBär
Re: Replacing/Repairing ALPS key switches
« Reply #1 on: Wed, 21 August 2013, 06:57:44 »
Ripster has an Alps disassembly guide that might help: http://imgur.com/a/elAFF#1
Offline morpheus
« Reply #2 on: Wed, 21 August 2013, 07:05:26 »
The first part, taking it out, doesn't look that hard, but the rest of it just looks confusing.
Also, is soldering involved in replacing an Alps switch?
Offline BlueBär
« Reply #3 on: Wed, 21 August 2013, 07:24:20 »
If you want to replace the whole switch, yes. It depends on how damaged the switch is if you need to replace the whole switch, but I think you should be able to avoid this. Can you open one of the switches following the guide and take a photo with a lot of light so we can see details? Also maybe a shot of the PCB in case not the actual switch is broken but something on the PCB.
« Reply #4 on: Wed, 21 August 2013, 07:44:09 »
If you going to be removing some switches and wanted to replace them with different ALPS switches you can buy the matias clicky and/or quiet switches from mechanicalkeyboards.com in as small as a 5 pack. They can be found under accessories.
Offline BlueBär
« Reply #5 on: Wed, 21 August 2013, 07:49:27 »
7bit has started a group buy for Matias switches on DT with 0.24€ per switch which is quite a bit cheaper.
« Last Edit: Wed, 21 August 2013, 08:22:45 by BlueBär »
« Reply #6 on: Wed, 21 August 2013, 08:05:34 »
7bit has been busy lately and it might be a while before he ships anything out. I ordered some matias switches from him and paid extra for shipping 2 months ago and they have never been shipped yet.
And after shipping and paypal fees the one's from mechanicalkeyboards.com are not any more expensive if you only need the 5 switches. And actually they are cheaper if you buy the larger 110.
« Reply #7 on: Wed, 21 August 2013, 08:06:34 »
But that only works if the OP wants Matias switches...
« Reply #8 on: Wed, 21 August 2013, 08:07:30 »
And is why I said this
Is there some place you can order other ALPS switches to replace defective ones?
I'm just offering an option that many people may not know about.
« Last Edit: Wed, 21 August 2013, 08:10:47 by SpAmRaY »
« Reply #9 on: Wed, 21 August 2013, 08:09:07 »
Not really. It's probably easier to try and repair the switch. Alps switches are hard to find loose. Easiest way to get more of X switches from X board is to buy a second board.
Offline BlueBär
« Reply #10 on: Wed, 21 August 2013, 08:22:28 »
Sorry, my fault, I mixed up currencies.
« Reply #11 on: Wed, 21 August 2013, 08:29:34 »
Misread obviously, sorry. You seem a little defensive though?
Offline Burz
  • maybe get a blister on yo' little finger...
« Reply #12 on: Wed, 21 August 2013, 08:33:41 »
I bought several extra Monterey switches from MrInterface last year. He likes ALPS boards and you can ask him over on Deskthority if he has any extras that match your board. You can also make a Wanted posting here or on DT.
You could also buy non-matching switches and move existing ones around so that the new ones end up in seldom-used places like PrtScn/Scroll/Pause.
I'm not terrific at soldering, but I was able to replace the bad switches in my Minitouch without much trouble, and now you couldn't tell it had switches replaced. For just a few switches, I didn't bother with a desolder tool and instead kept wiping the soldering tip onto a piece of foil to get the excess solder off while removing the old switches.
Matias Mini QuietPro  \\ Dell AT101W - Black ALPS  \\ SIIG MiniTouch x2 White XM - Monterey  \\ Colemak layout.
