Author Topic: Shine 3 Troubleshooting  (Read 1611 times)
Offline ShakeR
  • * Commercial Vendor
    • http://mechanicalkeyboards.com
« on: Wed, 21 August 2013, 11:25:30 »
MechanicalKeyboards.com - What do you type on?
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: Shine 3 Troubleshooting
« Reply #1 on: Wed, 21 August 2013, 21:28:26 »
Nice! This will help many people. Even myself when I order next month.
Offline Invaderscs
« Reply #2 on: Thu, 22 August 2013, 01:03:53 »
This seemed to fix most of the FN locking up problems but not all. Whenever I go to change the spacebar RGB LED's to one of the saved profiles it still locks up except mine doesn't seem to come back. It just resets with the usb disconnecting sound every 10 seconds or so, but I have to unplug it and plug it back in to fix it. This seems to be the only thing that I have found that makes it lock up after the firmware update.
Offline Skull_Angel
« Reply #3 on: Thu, 22 August 2013, 14:36:44 »
My girlfriend is having similar issues with RGB settings of the spacebar crashing the keyboard; only way to bring it back is either to reboot or unplug the board.
Offline falkentyne
« Reply #4 on: Fri, 23 August 2013, 05:23:55 »
They just released 1.14 firmware which should fix all of the RGB spacebar lockup problems (and adds aurora mode).
Offline Invaderscs
« Reply #5 on: Fri, 23 August 2013, 10:11:03 »
Just downloaded the new firmware update and it seems that all the issues are fixed. Good job ducky.
« Reply #6 on: Sat, 24 August 2013, 03:17:48 »
That was a quick response from Ducky - good!
Offline Skull_Angel
« Reply #7 on: Sat, 24 August 2013, 23:20:48 »
Double checked, seems all issues are cleared.
Offline C5Allroad
« Reply #8 on: Thu, 05 September 2013, 12:40:33 »
Wow Ducky is really making it hard for me to chose Corsair.... Corsair doesn't seem to stand a chance.
