Author Topic: trackball with 360° scroll?  (Read 5182 times)
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« on: Thu, 22 August 2013, 11:10:09 »
I'm looking for trackball that by pressing a button (or holding it down) converts the ball into a 360 deg scroller (basically in a 2D mouse wheel). Does something like that exist?
Offline davkol
  •  Post Editing Timeout
Re: trackball with 360° scroll?
« Reply #1 on: Thu, 22 August 2013, 13:18:46 »
I believe it could be done partially in software. For example, I use Logitech TrackMan Marble with emulated wheel for scrolling—to achieve that I have something like this in xorg.conf:
Option "ZAxisMapping" "4 5"
Option "XAxisMapping" "6 7"
Therefore, you could either use something like Cherry MX Lock for the modifier (EmulateWheelButton), or add some dongle with a button, that would change HID, before the trackball.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #2 on: Thu, 22 August 2013, 13:31:56 »
thanks for your reply and THANKS for the linux example :) (I was expecting some weird windows only software install).
It is not completely clear to me how you switch from one mode to another though. I seem to understand that you added an external button, is that right? How do you connect that to the internal circuitry?
Offline davkol
« Reply #3 on: Thu, 22 August 2013, 13:49:48 »
I use ordinary boring EmulateWheelButton, i.e. I keep the 8 or 9 button pressed while scrolling, but if you could replace that button with a Cherry MX Lock, I guess it would work as expected.
Offline The_Ed
  • Asperger's... SQUIRREL! I'm Anal Retentive *****!
« Reply #4 on: Fri, 23 August 2013, 00:26:03 »
Dorkvader asked me to put this very thing into my code for the ADNS-9800 laser sensors were using for custom trackballs. I have a feeling that only vertical "ball scroll" will be supported in my 1.0 code release as horizontal looks to be tricky for windows. But who knows I may have figured it out in time for 1.0, but it will for sure be in 1.1.
Reaper "frelled" me... Twice... Did he "frell" you too?... *brohug*
I'm camping for a week, and moving twice in a month. I'll get back to you when I can (If I don't then just send me another PM).
R.I.P.ster
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #5 on: Fri, 23 August 2013, 01:35:49 »
keep us posted! do you have any custom trackball pictures/tutorials?
Offline The_Ed
« Reply #6 on: Fri, 23 August 2013, 01:56:49 »
It's still quite a way off since I don't even have all the parts yet (Some stuff takes FOREVER to arrive from China...). After I have all the parts I can actually build the stuff and test the code I have so far to see what works and what doesn't. Then after I fix the parts that don't work I'll release 1.0 of my code. I have said before that it will be LATE September at the EARLIEST, but it's looking like it'll be October now. There's only so much I can do when I can't test stuff yet.
Horizontal scroll is looking even trickier now... It looks like a lot of support for it is tied to drivers running on the computer instead of something easier like Virtual-Key Codes... Maybe someone else here can figure out horizontal scrolling for me, it's giving me a headache...
R.I.P.ster
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #7 on: Fri, 23 August 2013, 02:02:45 »
install linux :)
anyway, thanks for the update. looking forward to seeing your custom trackball. What about the case? 3d printed?
Offline The_Ed
« Reply #8 on: Fri, 23 August 2013, 02:11:06 »
I'm modding both Me and my Dad's Microsoft Trackball Opticals. I'm thinking I'm probably gonna have to have a part 3D printed to attach the ADNS-9800's to the ball sockets, but I have no idea how to 3D model...
I don't like Linux, it's Windows 7 for me.
R.I.P.ster
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #9 on: Fri, 23 August 2013, 02:47:06 »
wow it works! I just put this in my /etc/X11/xorg.conf.d/10-evdev.conf
Code: [Select]
Section "InputClass"
Identifier  "Mouse0"
Driver "evdev"
MatchIsPointer "on"
MatchDevicePath "/dev/input/event*"
Option "EmulateWheel" "true"
Option "EmulateWheelButton" "9"
EndSection
now if I press the button #9 I get a 360° free scroller! Thanks linux!
Offline davkol
« Reply #10 on: Fri, 23 August 2013, 03:50:59 »
But you have to keep that button pressed, don't you?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #11 on: Fri, 23 August 2013, 03:59:25 »
yeah, fair enough. I could replace that with an on/off switch if I find one of the right size
Offline davkol
« Reply #12 on: Fri, 23 August 2013, 04:16:02 »
...or write a Pystromo macro. However, it doesn't work with my marble due to some nasty bug.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #13 on: Fri, 23 August 2013, 04:26:21 »
very interesting... gotta investigate into this pystromo.
