Author Topic: Will Poker X case fit Poker II?  (Read 1464 times)
Offline Rafen
« on: Thu, 22 August 2013, 18:11:32 »
I was wondering if the stock Poker X case would fit a Poker 2? I would like to find a couple if they do so I can paint them different colors. Thanks ahead of time.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
Re: Will Poker X case fit Poker II?
« Reply #1 on: Thu, 22 August 2013, 18:41:40 »
Yes, they used almost the same exact mounting points. Only difference is that on some of the older Poker X cases, they don't have a center mount. Given that you have a plate on your Poker 2, I don't know that you need it. It'd be nice to have, but I wouldn't say it is a deal breaker.
Hope that helps!
Offline Rafen
« Reply #2 on: Thu, 22 August 2013, 18:56:40 »
Thanks a lot!  I think I will post a classified ad to see if I can get a couple of them.  :thumb:
