Author Topic: HHKB dip mode switching between mac and windows  (Read 4960 times)
Offline jophde
« on: Fri, 23 August 2013, 11:03:42 »
I just got a HHKB and I really love.  I most work on OSX so I have dip switch 2 on for mac mode.  I have a windows partition I use occasionally I have found that the keyboard is not recognized if it is in Mac mode.  Changing the dip switches every time I switch OSes is a huge pain so I was wondering if anyone knew of any alternatives?  All of the switches off works fine in Windows but then the delete key and modifier key's don't on Mac.
Offline esoomenona
  • Gnillort?
Re: HHKB dip mode switching between mac and windows
« Reply #1 on: Fri, 23 August 2013, 11:13:37 »
I just plugged my HHKB into my Windows laptop in "Mac" mode, and it works just fine. I typed this message on it.
Offline jophde
« Reply #2 on: Fri, 23 August 2013, 11:16:57 »
Weird I will check out Windows update or something.
« Reply #3 on: Sat, 24 August 2013, 03:18:52 »
You can switch the modifier functions on System Preferences on the Mac.
