Author Topic: Changing it up at work.  (Read 2449 times)
Offline itlnstln
« on: Mon, 17 November 2008, 16:13:20 »
I put my Model M back on my work rig since I don't want anything to happen to my Evolution (it was expensive, and they don't make them anymore, don't cha know?) while I am in and out of work for vacation during the holidays, and I forgot how incredibly loud the Evolution was in comparison.  The noise level in the office must have dropped about 50dB since I switched back.  The Evolution will still be in use at home, and is certainly going to stay in use, and, as a matter of fact, I am looking to add another to the family in a few weeks.  While my Evolution is on Xmas vacation, I will probably try to do a little surgery to it to see if there is any way I can dampen the noise (even I appreciate the massive reduction in noise switching back to the M) and remove the programming chip to keep it from spazzing out (this gets annoying after awhile).  I might be abusing a Dell AT101W for a few weeks, too, for sh*ts and grins, but, for now, it's back to the M.  Thanks for listening and for your thoughts and concerns.  Group hug time.
...Or not.
Offline lam47
« Reply #1 on: Mon, 17 November 2008, 16:54:45 »
Hugs.
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline wellington1869
« Reply #2 on: Mon, 17 November 2008, 17:04:06 »
If you try anything with grease, let us know your experience (and audio clips would be great) ;)
I just dampened the gunshot spacebar on the m10 with a judiciously placed piece of velcro. Worked like a charm, spacebar is no louder than the other keys now. Had to place the velcro on top of the cherry switch itself (gunshot was the spacebar's underside hitting top of switch -- not spacebar bottom hitting keyboard bottom as I initially thought).
I feel your pain.
using: ms 7000/Das 3
