Author Topic: hkkb normal and s  (Read 2497 times)
Offline evolyn
hkkb normal and s
« on: Sat, 24 August 2013, 23:39:03 »
whats the diffrents between the normal ones and the s ones they are almost double the price.?!
Offline jameslr
Re: hkkb normal and s
« Reply #1 on: Sat, 24 August 2013, 23:44:32 »
Type S is silent.
CM Novatouch | Filco MJ2 TKL w/ HID Lib | REΛLFORCE 87U 55g | CM QFR
Offline chill1217
« Reply #2 on: Sat, 24 August 2013, 23:44:52 »
the s version has a foam ring around the plunger to dampen noise when it hits the housing.  the "clack" sound when the key resets to its original position after being depressed.  i think marketing says it decreases sound by 30%
if you want the type s, i think using a japanese proxy for amazon.jp will be much cheaper and you'll save $150
« Last Edit: Sat, 24 August 2013, 23:48:18 by chill1217 »
Offline evolyn
« Reply #3 on: Sat, 24 August 2013, 23:45:20 »
but why the pricediffrence?about 200dollar Oo
Offline evolyn
« Reply #4 on: Sat, 24 August 2013, 23:46:20 »
if you want the type s, i think using a japanese proxy for amazon.jp will be much cheapper and you'll save $150
thx men i pref clicky sound :D haha click click makes happy
Offline meiosis
  • Time
« Reply #5 on: Sat, 24 August 2013, 23:46:35 »
In japan price diff is like $60-80 elite keyboard just has a larger markup. HHKB from japan is $240 after all costs, HHKKB type S is like $300
Keyboards:
Aripeko TKL
Offline Michael
  • Formerly Bro Caps
« Reply #6 on: Sat, 24 August 2013, 23:55:07 »
Hey evolyn -
If you feel adventurous, you could do what o2dazone and I did to our HHKB's. The two choices would be dental bands, or cutting out your own o-rings.
Dental bands (cheaper, and takes less time): The caveat to this, is that it lessens the travel of the key, but you still get a tactile feel. It's what I am using, and I actually like it a lot.
O-ring modification: This takes quite a bit of labor to do, but is more spot-on to the factory Type-S silencing
I also lubed the sliders on my HHKB, and it gives it a much more solid feel. almost zero keycap rattle and creates, imo, the smoothest switch I have used. (the pink highlights indicate where to lube)
Offline evolyn
« Reply #7 on: Sun, 25 August 2013, 15:49:47 »
Hey evolyn -
mhhh don't know sounds really nice
Offline ___q
« Reply #8 on: Sun, 25 August 2013, 16:13:14 »
The o2dazone cut-your-own-orings modification is cheap and works great (at least it did on the 87U on my desk at work). I haven't tried the dental bands version, I was worried about the slightly reduced key travel.
It was a pretty big pain to do, though,
Offline Wildcard
  • When caffeine isn't enough
« Reply #9 on: Sun, 25 August 2013, 16:42:28 »
I believe I've also read the Type-S is engineered a big tighter and the plungers/holes are a closer fit. I don't own a Type-S so I haven't been able to confirm this.
