Author Topic: Another so-called good deal, NIB Model M on sale!  (Read 1707 times)
Offline berserkfan
« on: Sun, 25 August 2013, 03:52:40 »
The catch?
It's a Model M rubber dome (according to seller)!
http://www.ebay.com/itm/Brand-New-in-Sealed-Box-IBM-Model-M-Keyboard-/221272794825?pt=PCA_Mice_Trackballs&hash=item3384e2e6c9
Are rubber domes really worth that much? We must have some rubber dome fans willing to pay so much.
Offline phoenix1234
« Last Edit: Sun, 25 August 2013, 04:13:48 by phoenix1234 »
I like linear switches
Offline bazemk1979
Re: Another so-called good deal, NIB Model M on sale!
« Reply #2 on: Sun, 25 August 2013, 07:33:00 »
The catch?
they are worth if you like quiet, and yes its a rubber dome by looking at the part number 71G4644
Strange it is new but the Styrofoam bed is missing.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Sun, 25 August 2013, 09:23:26 »
WHAT A RIPOFF
« Reply #4 on: Mon, 26 August 2013, 07:55:29 »
the rubberdome keyborads share a lot of parts in common with a "normal" M. The case, controller, memberane, barrel frame (chimneys as unicomp calls it) cable and plate are all the same. I think only the keycaps mat and springs/hammers are different. It'd make a good parts unit or cheap conversion to BS if you wanted a project.
It's not bad for a rubberdome, but then again, I think plate mounted rubberdomes aren't bad.
