Author Topic: Krog's QFR Topcase Mod Thread  (Read 23622 times)
Offline Krogenar
  • The Kontrarian
    • Buried Planet
Re: Krog's QFR Topcase Mod Thread
« Reply #50 on: Wed, 13 November 2013, 12:51:18 »
Hey, those are some pretty cool experiments!
LOL, thanks! I still have one more QFR case to destroy! I'm tempted to try a complete flocking, or just a band, as seen in the red/green case. If you check out my Flocking thread, you'll see that flocked keycaps (specifically spacebars) are going to have issues eventually. Single keys aren't so bad (clip your fingernails and we'll be in great shape) but spacebars... they need work.
Quote from: Photoelectric
I like the red--seems to have some orange to it?
Yeah, it's not a great photo. It looks like a Christmas red -- some blue component to the color. It's not a candy apple red, though.
That crackled finish could have resulted for other reasons, like painting when it's too cold out or having some surface contamination under the paint.
It is cold in the area where I painted this, and not terrific-ly clean. I flocked the band around the case by hanging it from a hook, which worked very well.
You can use some fine-grit sandpaper to try wet-sanding it a bit, something at least 1000-grit and up.  Just make sure to wash your hands before every time you touch this cover, as if you put any more paint onto it, you're depositing some amounts of oils onto the red paint.  If you do wet-sanding, I'd rinse it off REALLY well with some detergent to wash off any sanded particles, as the color will turn chalky and splotchy otherwise on the surface, and then leave it to dry thoroughly.  Then wipe it with some fiber cloth--I've found that paper towels leave some dusty fiber pieces on the surface, and I have to use compressed air cans to remove.
(snaps off a salute)
I previously wet-sanded under running water at a slop sink used for cleaning brushes, etc. But I hadn't actually thought to wash it with detergent afterwards. I'm going to follow your suggestions (I need finer sandpaper) and will report back, regardless of the outcome. So, if I put any oils on this case (finger oil, even) it's going to hurt me when the clearcoat is applied, correct? Also, as I wet-sanded the "mud-cracks" away the surface looked pretty good, but then I would towel it down, and only then would it become apparent that I needed to do more sanding. So I would wet-sand, dry, examine for remaining trouble spots, and then re-wet and sand again. Do you do something similar?
Anyway, after you apply your stencils and paint another color, you'll definitely end up with some raised edges, because the spray force is usually too high from rattle cans, unless you use specialized airbrush equipment.  I'd cover up the part entirely, just leaving the spots you want painted in a different color exposed, and spray from a distance, misting on the new color.
Gotcha. I figure some doubled-up newspaper will do to cover the other areas.
Sanding any raised edges is risky too, as you might end up chipping off the raised paint and end up with a jagged line.  You can do a little bit of smoothing, but otherwise I'd just go over it with Clear.  Either you can do a lot of Clear and sand that to smoothness later or just a bit of Clear for protection and accept some unevenness.
I was thinking of using a font that could accept a small amount of unevenness, or distressing, and still look ... intentional?
If you want stripes, check out your local auto supply stores.  One of mine sells silver, gold, black, and chrome sticker stripe rolls in various widths, meant for car decoration.  You can apply those under or over clear coats.
I didn't realize I could clearcoat over it! The vinyl I use in my work is probably suitable; I'll try the really thin "high performance" vinyl.
Sorry for the long stream-of-consciousness reply--just woke up  :-\
No worries; wall o' texts don't bother me at all. Thanks again for all your help.  :thumb:
Quote from: Samuel Adams
Offline Photoelectric
« Reply #51 on: Wed, 13 November 2013, 13:14:52 »
I wouldn't touch the surface with a towel, if it's a regular towel.  It can leave fibers stuck to the paint, and then you'll be painting over those, they'll show up as uneven bumps.  Plus the towel would have to be perfectly clean. I always wash with a detergent after sanding (I use 7th Generation free and clear type for everything, since it doesn't destroy my hands from frequent cleaning and also rinses off really well), rinse VERY well, and then leave to air-dry for an hour or two.  Then wipe with microfiber or similar--something that doesn't contain oils or grease or would leave fibers behind.  It's not a huge deal if you get some onto the surface, but it's best not to for the cleanest smoothest finish possible and durability--you want the paint to cure well and stay strong in the long run.
As for temperatures, I wouldn't paint at anything under 60F.  I've had some poor crackling and cloudy results when painting in cold temperatures, so I even prefer 65F and up.
Smoothness-wise, just do what seems right.  It's not like you have to paint to someone's specifications.  You're essentially working on an art project, so it's all subjective.  If the roughness looks good and you like it that way--nothing wrong with just leaving it like that.  Due to the limitations of spray paint cans and spraying environment, I always improvise and go with what seems natural for each particular cover, unless I'm confident that I can get the results I need by doing a lot of extra sanding and polishing.
Painting over vinyl: I'm not sure--I'd test on a small strip of vinyl on some scrap piece.  I know that those metallic stripe vinyls are fine.  But they do have some thickness, so there'll be a bit of a raised edge around them.  And if you use something chrome-like under Clear, it won't look very good, unless you can polish your Clear to perfect smoothness over the chrome.  I'd either use matte or just put the stripes over the clear coat as stickers.  Here's matte gold over clear as stickers
As a potential bonus--those stripes are removable :)
« Last Edit: Wed, 13 November 2013, 13:21:26 by Photoelectric »
Offline vztrx200
« Reply #52 on: Mon, 25 November 2013, 17:26:01 »
Greetings from the UK!
I'm an utter noob here, however I work with commercial spray paints on a daily basis respraying everything from plastic to metal and laminate surfaces. I know a lot of the basics have undoubtedly been covered here but I'd just like to reitterate several fundamentals when it comes to respraying, rules that essentially I swear by and that I think will come in handy for anyone looking to do a custom spray job on their keyboard, or anything else for that matter.
1) Preparation
I know this is the really boring part and whenever we begin a project everyone has that urge to just grab the paint and get busy, but I cannot emphasise enough the necessity of putting time and effort into preparing your surface. Ideally all surfaces that you wish to paint should be sanded to a fine degree and thoroughly cleaned and brushed down so as to be clear of all grime, dust and detritus, paying particular attention to burs and moulding marks on corners and edges. Previous posts in this thread seem to have it spot on in terms of what type of sand/glass paper to use, however a quick and easy alternative to sanding can be fine sand-blasting should you happen to know of anyone with the appropriate facilities.
2) Location
The location in which you choose to conduct your re-spray job is very important. You should have available to you at least one flat surface and one wall against which to rest your keyboard case. This should preferably be either indoors or in another form of 'still air' environment (i.e. garden shed, greenhouse or garage). Additionally, if this is not a designated painting area and getting paint everywhere is a problem you might want to consider covering these surfaces with well taped-down material such as newspaper or ideally cardboard or plastic. Always cover a greater surface than you think you need to because spray paint does have a tendency to travel and the last thing you'll want is to end up doing is repainting the entire garden shed fluorescent green because Mum, Dad or Auntie Doreen did not appreciate the creative finesse of your accidental overspray. Again, having masked the area ensure that any dust, dirt or debris is removed from the surrounding environment in which the painting will be taking place.
3) Climate and Temperature
Of key importance to any spray painting project is the climate and ambient temperature of where you choose to paint as paint particulates react to whatever atmospheric conditions they encounter upon leaving any form of compressed spraying device. Consequently if you spray in wet or cold conditions spray paint, like any liquid medium, is prone to condense 'mid-air' and will therefore leave your incredibly well prepared and buffed down surfaces with a very obvious bobbly, dimpled or stippled effect. Therefore ideal temperature conditions should be between 17 and 25 degrees centigrade (sorry for those not in the UK I'm not sure what the Fahrenheit equivalent is). And once again I cannot emphasise enough the importance of spray painting in a still air environment. Personally I am fortunate enough to have access to a proper spray painting booth with an extractor fan so if you, or anyone you know, has access to similar facilities I'd highly advise making use of them if you can. Obviously though the vast majority of us will not have such facilities in which case finding an appropriate location where you can avoid drafts and sudden gusts of wind is vital - certainly try to avoid areas in hot direct sunlight, under trees or anywhere your pets might have easy access to because picking out bits of leaves, dead bugs or pet hairs (or anyones hair for that matter) from a half completed paint job is a chore best avoided.
4) Ventilation
When inhaled commercial spray paints are damaging to your health so before doing anything ensure you have an appropriate mask to prevent you inhaling fumes and particulates. Your cheap DIY dust mask will normally do for the odd small job here and there however if you plan to use spray paints on a large project or on a regular basis the I would highly advise investing in a decent particulate mask with replaceable charcoal filters. Additionally, while as I mentioned,you should ideally be spraying in a 'still air' environment it should nevertheless be a place with adequate ventilation to allow fumes to escape.
5) Paint Prep
While all off-the-shelf spray paints come ready mixed they often spend a significant part of their lives either sat in boxes or on the shelves of your local paint/DIY store. As a result this can cause any paint (even polymers and enamels) to congeal and separate, the heavier particulates sinking to the bottom of the can and the lighter at the top. This process can also be exacerbated by their being stored at varying degrees of temperature. Therefore before using any type of spray paint it is firstly very important to ensure that the can is at room temperature and, secondly, to spend at least 5 to 10 minutes agitating the can so that the metal ball inside does it's job of returning the paint to an even consistency. Ideally you should shake the can vigorously for the fore mentioned time or at least until your arm starts to actually ache (or you get what we call 'wankers cramp' here in England) before swapping to your other arm for an equivalent amount of time.
6) Setting Up
So once you've ticked the boxes in terms of location and paint prep you'll want to set up your case ready for spraying. As mentioned earlier in this thread it is important that you do not spray your case while it is lying down horizontally. Ideally, your spray paint can should always be held at right angles - a vertical 90 degrees to the surface you wish to cover. It may sound obvious but doing this will ensure that the paint is always delivered from the bottom of the can and therefore your paint feed will not be interrupted, sputter or spit as a result of the air inside the can entering the paint feed. To work against this take your case and lean it against your wall vertically ideally with it base (the shorter edge) on something other than the floor. I normally rest whatever I'm painting on a wire basket or plastic bottle crate which are both useful as the ridges prevent leaning objects slipping mid-spray while also allowing any overspray to pass right through and not pool at the base of the surface I am spraying. Not doing this and simply placing your keyboard cover on the floor, or in fact any smooth flat surface, will inevitably lead to overspray bouncing back up onto your cover from that same surface and thereby create an uneven delivery while also inconveniently adhering whatever dust and dirt has remained on the floor/surface to your lovely paint job.
7) Technique
Once again to reiterate a point previously made in this thread the key to a consistent spray job is to build up layers slowly... ever so slowly... in a series of very light layers. I cannot emphasise this enough!!!! Your first coat, regardless of colour, should hardly be noticeable and should, at most, only show up as a very light 'misting' upon your well-prepped surface. If you are worried that you will run out of paint then please please please just let let the paint run out as opposed to trying to cover it all in one go. After all you can always buy another can of paint tomorrow if needs be and it's far better to take your time and do a job properly than expend extra time, effort and money because you rushed to get everything covered in one go only to create a horrible gloopy mess. Also be aware that as the paint runs out in your can the more likelihood there is that air will enter the feed. Therefore it is often wise to try and not use every last drop of paint in your can should it start spitting and spotting on your otherwise perfect paint job.
When starting to spray you should have your spray paint can at least a foot away from your cases surface (ideally slightly further for your first few layers).  You should begin at least half a foot from the outside edge of your cover and move across it horizontally - left to right or right to left dependent on what feels best -  only releasing your finger from the nozzle once you are at least half a foot past the opposing edge. While this might seem wasteful in terms of overspray it is nonetheless very necessary in that it will ensure your paint will hit your surface when it is at its optimum flow, and also reduces the chances of any unsightly drops or spatters hitting your surface due to temporarily congealed paint in the spray nozzle. It is very important that you maintain an equal distance across the spray plane as you make this action. Naturally your arm will want to make an arcing movement that will bring the can closer to the surface of your cover as you move your arm across your body. Being aware of this and resisting this natural inclination is very important otherwise more paint will condense in the  middle areas of the case than at the edges.
8) Have Patience
When undertaking any spray painting job it is vitally important that you have patience and take your time, especially when it comes to building up layers to get a smooth surface. I personally have never seen a decent spray job that did not involve more than 4-5 layers (excluding undercoats) therefore having the patience to apply thin layers with sufficient 30 - 60 minute drying times (temperature depending) in between should be a pre requisite for anyone looking to do a decent job. There are several important things to remember here:
 - don't attempt to rotate or turn your case until it is totally touch dry.
 - instead of changing your angle to spray difficult edges and corners wait for your case to dry then rotate your case so that you cover these areas as part of your regular spraying action.
 - don't try to patch over any areas you may have missed in between layers, just remember to cover these areas with your next layer.
 - while the paint may be touch dry in a relatively short time  it will not be fully dry for over 24 hours, often longer!
9) Drying and Finishing
Before attempting to do anything with your finished case it will need to dry for at least 24 hours. Once it has you may still find misting, stippling or fuziness across your cases surface. Should this occur simply take a clean kitchen cloth or sponge, dampen it slightly with water and give your case a very light wiping down and that should help smooth away some of the more pronounced differences in texture. If you are especially fussy your local auto parts dealer should sell special finishing cloths that auto spray repair experts use to remove these 'bobbles', however I'd advise against using these if your case is anything other than metal as some of them contain a chemical residue that may react with plastics. Another way to combat this problem is use a clear polymer lacquer to smooth away these differences, an added benefit is that this will also make your paint job a lot more hard-wearing. To apply a clear lacquer these simply follow the same procedure as you did with the painting, though this time be even more aware of giving your layers sufficient drying time as the last thing you want to do is ruin your perfectly finished case with a nice big finger print or congealed drip.
Hope this has been of some help and apologies for any typos it's been a long day, good luck.
:thumb:
« Last Edit: Tue, 26 November 2013, 04:47:54 by vztrx200 »
« Reply #53 on: Mon, 25 November 2013, 19:28:55 »
I'm an utter noob here however I work with commercial spray paints on a daily basis respraying everything from plastic to metal and laminate surfaces. I know a lot of the basics have undoubtedly been covered here but I'd just like to reitterate several fundamentals when it comes to respraying, rules that essentially I swear by and that I think will come in handy for anyone looking to do a custom spray job on their keyboard, or anything else for that matter.
<big snip>
:thumb:
Welcome to Geekhack!
Wow!  Fantastic first post!!
Can we get this stickied somewhere?
Offline vztrx200
« Reply #54 on: Mon, 25 November 2013, 20:04:38 »
Thanks! Pleasure to be here - even if I am typing on a piece of c**p Dell 1421 right now. Yes sadly I'm yet to take the 'mechanical' plunge but I am looking to rectify this ASAP, hence my signing up and forum scouring.
« Reply #55 on: Mon, 25 November 2013, 21:03:41 »
<big snip>
:thumb:
Great post indeed!  Most of that is already here:
http://geekhack.org/index.php?topic=44191.0
but not stickied :(
Offline vztrx200
« Reply #56 on: Tue, 26 November 2013, 03:06:49 »
Haha sooooooo didn't see that, yeah ignore me and just follow what the other poster says instead, it's much more detailed. Someone sticky that one for the sake of gloopy badly sprayed cases everywhere! :'(
« Last Edit: Tue, 26 November 2013, 03:13:39 by vztrx200 »
« Reply #57 on: Tue, 26 November 2013, 03:58:41 »
A bit of both won't hurt!
« Reply #58 on: Tue, 26 November 2013, 06:08:50 »
Why is all this in krog's qfr thread?
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #59 on: Tue, 26 November 2013, 06:32:17 »
That is a really good question, LOL!
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #60 on: Tue, 26 November 2013, 13:52:50 »
Ok, an update -- after a few false starts (oversanding) I've finally put two coats of clear gloss on my current QFR case. And I purchased a QFR (my rapping skills were no match for lastpilot and others) so I'll be able to actually put the case to some use. I'm going to let this case dry over the holiday break (5 days or so) and then consider whether polishing is necessary or wise.
45909-045911-1
Then, the vinyl!
45913-2
My company used to do a lot more cut vinyl in the past, so I started digging through our more exotic rolls of vinyl. There were fluorescents (bleh.) and three stood out -- I have a vinyl meant to simulate frosted or sandblasted glass (could look interesting) and a metallic (very metallic -- you can see my reflection in it) gold, and a matte black. I've mocked up a few designs, and I think I may go with something like this:
45915-3
The word "mechanical" is going to go roughly where the CMSTORM logo is normally located on branded cases -- the back side, to the right. Pinstriping will go all around. The yellow would be the mirror gold, and black is matte. Hopefully my pinstriping skills are up to the task.  :thumb:
« Last Edit: Tue, 26 November 2013, 14:03:02 by Krogenar »
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #61 on: Mon, 02 December 2013, 12:50:34 »
Second post updated, with the flocked case attached to a QFR: http://geekhack.org/index.php?topic=47581.msg1015003#msg1015003
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #62 on: Thu, 05 December 2013, 09:29:26 »
Third post updated with red QFR w/ matte black pinstriping and logo.  :D
http://geekhack.org/index.php?topic=47581.msg1015006#msg1015006
« Reply #63 on: Thu, 05 December 2013, 17:22:32 »
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #64 on: Fri, 06 December 2013, 08:32:46 »
 :thumb: :thumb: :thumb:
Thank you! I've still got one case left, and I've been reading up on how to clearcoat over vinyl so that there's no detectable edge. I'm thinking of:
1. Take the Hulk case and trying to clean it off and giving it a flocking. I discovered that the the best way to flock anything is to suspend it up in the air. For the Hulk case with the strand of masked flocked all around the edge I used a metal hook to hold it up, and it worked really well. I think this goes for cases, keycaps, everything -- get it up in the air, and it's likely to paint/flock better. Also, getting an even coating of paint is tough -- I'm thinking of investing in a airbrush. They sell for a little over $100, which isn't too horrible.
2. I still want to try to make a whiteboarded dry erase case. You could write all over it, and then clean it off. I considered a chalkboard surface, but the dust from chalk would probably gunk up the electronics, so that won't work.
3. Glow-in-the-Dark white case. Just because? I figure paint the case white, then apply the GitD coating, the a clearcoat to protect it all.
4. Also been thinking about just doing a vinyl wrap on the entire case, like they do for auto wraps. All those bends, though, in the key wells.
5. White nylon flocked case, using the hanging method.
Anyway, just thinking out loud.
Offline Jixr
« Reply #65 on: Fri, 06 December 2013, 09:22:19 »
i've already tried a glow in teh dark case, panited white, then with glow paint over it, it didn't work out well at all.
to give it a consistant glow you need tons of layers ( i used a whole can and it still came out crappy ) its pretty splotchy, but it did glow well, just not very uniform or evenly and looked grainy, and in the daylight the color was pretty aweful.
Offline Krogenar
  • The Kontrarian
    • Buried Planet
« Reply #66 on: Fri, 06 December 2013, 12:01:02 »
Ok, then scratch that. I'm going to see about flocking the case with better success. Maybe a nylon blue flock would work.
